JohnDF's JKU
March 8, 2015
9:11 pm
Forum Posts: 6985
101sp_Permalink sp_Print
Awesome pic John!
Can you see if you can post the dual JKU pic Elena has?
March 8, 2015
9:48 pm
Forum Posts: 3049
102sp_Permalink sp_Print
Wow!! Looks great!!
What's your thoughts on the synergy kit so far?
9:55 pm
Gilbert & Betty
El Dorado Hills
Forum Posts: 1394
103sp_Permalink sp_Print
Wow looks good how much lift. mr-green
March 9, 2015
5:35 am
Forum Posts: 9523
104sp_Permalink sp_Print
Awesome pic John!
I'll have her send it to me so I can post it.
Thanks again for your all your help.
5:35 am
Forum Posts: 9523
105sp_Permalink sp_Print
Gilbert & Betty said
Wow looks good how much lift. https://posse4x4.org/wp-content/sp-resources/forum-smileys/icon_mrgreen.gif
Thanks. It's a 3" lift.
5:57 am
Forum Posts: 9523
Wow!! Looks great!!
I like it now that it's complete. It rides really nice and all the steering feels good. We set everything the way the instructions said and the Jeep drives perfectly without any re-adjustments.
It's got decent flex but not fantastic. Of course that's comparing it to my old TJ long arm kit that flexed like crazy. I'm sure it will be more than enough on the trails and I'm sure it's comparable to a lot of the standard length arm kits that are sold.
Everything fit really good and went together pretty easily. The big pain in the butt parts were the front shock mounts and the tie rod flip kit. They took the most time to get done and it didn't help that the front shocks had the wrong sized sleeves. The nicest parts were the beefy track bar brackets and they were super easy to install. The high steer works perfectly with no bump steer, feels stock. All the parts are strong and well thought-out. I'm happy with it.
8:23 am
Forum Posts: 6985
107sp_Permalink sp_Print
I'm always glad to help out... For food!
I think the jeep turned out well for phase 1 of his work.
Installing springs greater than 3" with stock-length control arms requires some creativity.
March 9, 2015
8:54 am
Forum Posts: 3049
108sp_Permalink sp_Print
We need moar pictures!!no-pics
Are you running stock control arms anywhere or were they all replaced? What was so difficult about the drag link flip?
10:13 am
Forum Posts: 6985
109sp_Permalink sp_Print
All the control arms were replaced.
Drag link took time because the initial taper effort didn't work to our satisfaction. As a result we re-drilled and sleeved it. Then the sleeve was tight so it took a lot of time getting the nut on far enough to clear a cotter pin.
Both Front and rear track bars were retained. But both were reinstalled in to beefed up lower brackets.
March 9, 2015
11:09 am
Forum Posts: 3049
110sp_Permalink sp_Print
Cool, does that flip feel solid or can someone screw up the knuckle doing it wrong?
12:21 pm
scoped
Forum Posts: 626
111sp_Permalink sp_Print
Nice! !
March 9, 2015
1:20 pm
Forum Posts: 9523
The flip kit comes with a drop in bung. You have the choice to use a tapered bit or drill it straight and drop in the tapered bung. Smart money says to try the taper bit first and if that doesn't work well then go ahead and drill it for the bung. Although a lot of work, it's rock solid and steers like stock. And yes, you could screw up your knuckle doing it, which is why I let Brad do the drilling :)
6:51 pm
Josh
Forum Posts: 1631
113sp_Permalink sp_Print
The lift looks good John. Congrats!
8:11 pm
Forum Posts: 9523
114sp_Permalink sp_Print
Thanks everybody. Can't wait to actually drive a Jeep to the meeting on Thursday instead of a Honda :)
8:41 pm
scoped
Forum Posts: 626
115sp_Permalink sp_Print
Boom! For the win
(You could always drive the Jeep and Honda to the meeting and then dive over the Honda with the Jeep for a display of ultimate win)
March 10, 2015
9:35 pm
Forum Posts: 3049
116sp_Permalink sp_Print
Hahahahahaha!!
5:04 am
Forum Posts: 9523
117sp_Permalink sp_Print
But then my wife would kick my butt. It would be embarrassing and all that "win" would go away.
2:57 pm
Forum Posts: 9523
118sp_Permalink sp_Print
So, my list of to do items. . .
I still need to install the rocker guards, the tube fenders, the tire carrier and spare, reprogram the tire size, and set the tpms to zero.
Then it's sleeve, gusset, and add diff covers. Probably throw on a new front drive shaft too rather than wait for the stock one to give it up.
I'm hoping to have all this done soon so that I can go on the Trail Maintenance Run. My plans for this season is to go on a few moderate runs with it to shake everything down before I tackle a run like the Rubicon. Don't want to break, scratch, or dent the new rig too soon.
10:38 pm
Forum Posts: 3049
119sp_Permalink sp_Print
Cool! The jeep looked really good at the meeting!
3:57 pm
Forum Posts: 9523
A fun little comparison pic. . .
https://posse4x4.org/wp-content/sp-resources/forum-image-uploads/johndf/2015/03/compare.JPGImage Enlarger
9:14 pm
k-jeep
Parts Unknown
Forum Posts: 2221
My Jeep was that little for 3 years. Didn't realize it was that long!
March 14, 2015
10:39 pm
Forum Posts: 6985
122sp_Permalink sp_Print
Aww, you found a picture with Gregg jeep! No, wait, his is white!
Sorry Greg... Im waiting on your build day!
March 15, 2015
3:00 pm
Forum Posts: 9523
Spare tire carrier installed. . .
https://posse4x4.org/wp-content/sp-resources/forum-image-uploads/johndf/2015/03/IMG_4040.jpegImage Enlarger
3:25 pm
Forum Posts: 9523
124sp_Permalink sp_Print
I also re-programmed my Jeep with the AEV ProCal module. I recalibrated my tire size and turned my TPMS down to "zero". Now my tire pressure reads zero psi but doesn't throw the stupid idiot light on. Super easy to use too.
10:35 pm
Forum Posts: 3049
125sp_Permalink sp_Print
Me too...
Currently Online: Jeff_R
JohnDF: 9523
Gregulator: 3049
Jeff_R: 1690
Josh: 1631
Gilbert & Betty: 1394
Members: 136
Topics: 4225
[email protected], Ski man, RomikaHill, JKJeepGirl, frostie_jeep, RockyRaccoon, [email protected], Rogersuisy, TacoDan
Moderators: Posse4x4: 1, BKGM Jeepers: 6985, Lynda and Guy: 195, kris_olof: 1082, Jamie (K6NUB): 722
Administrators: k-jeep: 2221
Today: Krawlman
Upcoming: Jeff_R, 2013JKUR, Robert & Amber, HaZaRdZoNe
