9:13 am
So Logan got a Jeep yesterday. It was given to him to get running again and do with what he wants... He wants it lifted, He wants 35's, He wants, He wants, He wants...
1996 Cherokee with 340K miles... He gave the lady $100 just because he felt he had to give her something. Been sitting for the past 6 months after someone tried to change the starter, and never got the new one in correctly. After a good bath, we will check out the starter situation and start a list of things to do. Was told the Power Steering pump is bad. Window switches on 3 passenger do not work. Rear drivers side door only opens from the inside. Lots of little things to keep him busy for the next year before he gets his license.
I did find this lift that looks like a good deal...
Let the fun begin...
12:56 pm
5:25 pm
6:52 pm
7:12 pm
August 4, 2014
3:05 pm
September 25, 2011
11:47 am
August 4, 2014
12:03 pm
7:22 pm
March 13, 2015
Perfect start for a build. 96 was the last year of the old body style but did have the unibody bracing upgrades like the newer ones. Lots of junkyard upgrades available for cheap. Front is already a high-pinion Dana 30. Go to pick-and-pull on a half off day and grab a 8.25 rear end out of a 97+ and you are ready for 35s.
8:40 pm
10:29 pm
December 13, 2015
11:45 am
March 13, 2015
Mike G said
Looks good I've always liked the xj's slap a long arm in front and some good chevy 63" in the rear and look out
X2 on the long arm (especially since you need 5.5"+ of lift for 35s and the stock control arm angles get rough over 4"),
Google "bastard pack" for some junkyard s10/dakota/xj rear spring recipes that are bolt in. Wont be as flexy as the 63s but wont require fabbing spring hanagers.
6:52 pm
August 4, 2014
9:46 pm
8:59 am
March 13, 2015
Logan Larson said
I have a Rubicon Express 5.5 Long Arm kit sitting in the garage.
Must have been one hell-of-a summer job for those deep pockets. Swing by roughstuff in loomis and pick up some unibody stiffeners. Will add a bit more fabrication to the install but the XJ long arm kits already require plenty of welding and grinding.
11:50 am
They do?
the one i installed was pretty easy. It required a hole saw and some spot welding from what I remember. It was easier than when I installed mine on my 'TJ.
1:29 pm
March 13, 2015
They do?
Interesting. I had the complete opposite experience.
TJs just had to optional 6(?) plug welds on the slugs that had to be ground smooth. The XJ I worked on had factory underbody coating that took a few hours to grind off and then the differences in floor stampings during the XJ production meant there was some hammering and grinding down of tabs required. I find getting the correct weld temperature for rosette welds on thin metal to be a pain compared to the TJ frame material.
That said, its been over a decade since I helped with that project and nearly that long since i put on my LJ long arm so I might not be remembering things unbiasedly.
2:50 pm
4:00 pm
March 13, 2015
BLTJeep said
Yep, gives the rig something more like a frame than the factory beer can material.
10:33 pm
7:43 am
kris_olof said
They do?
the one i installed was pretty easy. It required a hole saw and some spot welding from what I remember. It was easier than when I installed mine on my 'TJ.Interesting. I had the complete opposite experience.
Mine didn't have any extra work like the coating you had to deal with. It was an RE long arm front with leaf springs out back. The back is what made it easier.
