6:59 pm
Hi everyone. So amber and i have some big decisions to make here with the yj. We do need to keep cost in mind. Kris is hooking it up with a rear dana 44 for a case of beer! Thats way awesome. So trying to decide for cost control if im just better off putting the 35 back in and cromoly shafts front and rear. Or the dana 44? Concerned about the 44 because i just bought a new driveline, leaf springs, shocks and pinion angle shims snd U bolts. How hard is it convert the 44 to leaf spring? Is it possible? Should we just full coil over front and rear? Will i have to have driveshaft shortened? Will i have to re-gear the 44 and a new locker? Will i have to buy 2 new wheels for the lug pattern? Or do i buy a 44 for the front too? But a lot of cost is coming along with all of this. We just want it to be strong and affordable, if that is ever possible haha. Just give me everything you all know and options, ideas, information. I have a lot to learn. Thanks
5:40 am
8:22 am
8:45 am
October 28, 2016
12:06 pm
8:18 am
I’ve been broken down on the Rubicon, & other difficult trails, more than once & the stress of getting out overtakes the fun out of being there.
One of the initial considerations when upgrading your Jeep is doing so with heavier axles...a 44 over a 35 is a logical decision. The increased reliability outweighs the overall cost.
8:33 am
6:07 am
Robert, you might want to call a few shops like WFO and MC Motor Sports (MC is a club sponsor) and ask them about your options and approximate cost of parts and labor. I know WFO can give you good advice even if you don't end up having the work done there. I had my driveshaft shortened this year and it cost $180 from Driveline Services in Sacramento. As for the rest of your questions, talking to a shop might give you some valuable guidance even if you end up doing most or all of the work yourself. I will also text you the name a Jeep mechanic I know who does side work. He installed the Atlas transfer case in my Jeep this summer. He might be able to answer some of your questions.
10:43 am
Dana 44 is the way to go especially at the price your getting it at. Also all the bracketry will have to come off and new ones welded on in the proper location. As Jeff said contact a local shop and get their advise and suggestions. Another shop to look into is Varozza in Placerville they built the clubs Rock trailer. Ben over there does great work. JKU axels are a great upgrade and good place to start. There are also companies out there that specialize in con verting JKU axles to TJ and YJ configuration but the cost maybe prohibitive. Another thing to ask a shop is if they have any JKU front axles lying around you maybe able to pick one up at a good price. My to cents
11:11 am
2:14 pm
7:00 pm
March 13, 2015
So the 44 I have is a JKU 44 with 30 spline axles, disc brakes, and 3.21 gears. Since the YJ is leaf springs, swapping is pretty easy and you basically cut off all the factory brackets (torch or sawsall and grinder) and then weld on the spring perches. The only downsides for the JK44 is that is it a different bolt pattern and it is ~4" wider than the factory axle. I would suggest finding a JK or WJ front axle to pair with it. (WJ front axles are less than $300 at pick and pull).
To do this swap you would be looking at following in addition to new 5x5 bolt pattern wheels (typically need 17" wheels to clear the much bigger brakes):
-Rear axle - beer
-Rear Gears - $140 on summit for Spicer SVL
-Rear Locker - $400 to $1,000 depending on option
-Oil - $40
-HD Diff cover - $90
-Rebuilt part store brake calipers - $100~
-Yoke adapter or new yoke - $50
-Driveshaft shortening - $100~
-3.25" spring perches - $35
-3.25" u-bolts and plates - $100 (or u-bolt eliminator perches)
For the front:
-Junkyard axle ~$300
-gears - $140
-oil - $40
-HD diff cover - $90
-New tie rod - $150~
-Rebuilt parts store calipers - ~$100
-Yoke - $50
-minor driveshaft shortening - $100 maybe
I did an 8.8 swap a few years ago and while strong and cheap, I preferred the dana 44.
For an 8.8 swap you would keep your wheels and tires so you are looking at:
-axle - $175 from pick and pull
-flage adapter - $80
-rebuilt brake parts - $100
-Gears - $140 or free depending on ratio
-Locker - $500 to 1000
-u-bolt swap kit - $140
-driveshaft shortening $100
-oil - $40
-Wheel spacers to match front width - $90
7:45 pm
9:13 pm
March 13, 2015
Robert & Amber said
Holy smoke! Nice write up and all the info. Hmmm decisions. Thanks kris. If I keep the 30, can it handle ARB air locker and 35” tires? I have had no problem with lunchbox and 33”
Technically the 30 under your jeep or WJ/JK 30 could be built to handle a locker and 35s but I would look for a JK rubicon front 44 as a takeout axle. would be cheaper than the 30 spline kit and 30 spline locker when said and done.
10:02 am
10:04 am
8:16 am
Or if you want to just bypass it and go for matching axels I have a 90 ford f350 srw 4x4 for 2k be pretty easy to swap them into your jeep
8:26 am
9:44 am
Robert & Amber said
Dana 60’s? How wide are they? Whats the lug pattern?
Super heavy for your YJ. Expect to spend bucks for additional upgrades. 6" wider than stock typically for a front. Junkyard 60's can be more. Typically they are an 8 lug pattern, but can be adapted to most bolt patterns - not the YJ 5x4.5, or the JK 5x5. I run a 5x5.5 bolt pattern with my 60s. That's the minimum you can run. Most run a 6 lug or 8 lug. The 5x5.5 is the CJ bolt pattern so its quite common.
11:15 am
12:51 pm
4:16 pm
