I was thinking about that as well. You and I have both broken their product. I wonder how frequent this is.
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003"BKGM Jeepers" wrote: I was thinking about that as well. You and I have both broken their product. I wonder how frequent this is.
Bill broke his too..
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"JohnDF" wrote: [quote="BKGM Jeepers"]I was thinking about that as well. You and I have both broken their product. I wonder how frequent this is.
Isn't Bill's a newer model? Yikes! We'll test their durability in two weeks!!! 😉
Justin SubscriberJustin SubscriberI asked Bill if he broke his and he said he didn't. :? Are we just trying to start Swayloc rumors? 😏
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003"Justin" wrote: I asked Bill if he broke his and he said he didn't. :? Are we just trying to start Swayloc rumors? 😏
I could have sworn he said he broke his on that Strawberry run when Brad broke his. Who was it that broke one then?
But maybe I am just subconsiously trying to start crap 😳I used to wheel a lot. . .
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003I broke mine on strawberry. I don't think anyone else did on that specific run...
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003"BKGM Jeepers" wrote: I broke mine on strawberry. I don't think anyone else did on that specific run...
No, somebody mentioned breaking theirs in the same spot on that run.
Justin SubscriberJustin SubscriberMine broke before I got it. 😂 😂 😂 😂 😂
"Justin" wrote: Mine broke before I got it. 😂 😂 😂 😂 😂
You are just lucky. - RobD SubscriberRobD started this Subscriber
I got the Hydro assist tacked in today. It cycles good with no binding. Before I do the fianl welds and supports, I have to check to make sure that when the axle flexes that the ram doesn't hit anything...
Uploaded with ImageShack.us__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan - RobD SubscriberRobD started this Subscriber
First spot as shown in the picture didn't work 😈 once the suspension was compressed, the ram was hitting the pitman arm when turning...second choice didnt work either! With the way my front steering is set up for the low lift I have had to move the ram almost to the passenger knuckle and build new custom brackets and tabs to get it as close to the top of the tie rod..Round three was successful 😁 Problem now is running the hydraulic lines which don't have a lot of flex in them. I have been fighting with them for a couple hours trying to route them where they won't bind of rub on anything causing a leak.. Gave up for today 😈 maybe I should go back to running 5 or 6 inches of lift..Life would be much more easy when it comes to building and installing steering stuff 😁
Tomorrow I'm hoping to get the system filled and driving 🙄__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan - RobD SubscriberRobD started this Subscriber
All installed and driving good 🍺 Before when I would press my brakes, I would lose steering because of my Hydro boost brakes. Now I can turn the wheel with one finger with the brakes fully applied. I put my driver tire sidewall up against a pole then turn the wheel. The ram moved pushed the jeep sideways in the dirt 😁 No problem moving the 40's anymore...It took a little ingenuity to get everything to fit in there, but the pay off was worth it!!
Cost of the PSC ram to my door was 249.00..I put about another $30 into it..Less than $300 for top quality steering
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009Looks great!
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003Oh look...more stuff for the Hammers to rip off 😁
I used to wheel a lot. . .- RobD SubscriberRobD started this Subscriber__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003Great...now I'm even more excited to get there...this is going to be a long few weks.
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003Rob,
You should show some current pics of your jeep compared to those above. I recall most things are fixed and the body is straightened,Kathleen and Brad
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003"BKGM Jeepers" wrote: Rob,
You should show some current pics of your jeep compared to those above. I recall most things are fixed and the body is straightened,Ya Rob...all that bondo is going to look awesome when you smash that hood again...we'll be picking that stuff off the trail for an hour 😂
I will just plan on a much higher line at the end of Wrecking ball this time 😁 That was where I dented the passenger side hood, I can't remember where I did the driver side :?:
"JohnDF" wrote: [quote="BKGM Jeepers"]Rob,
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009Not sure if this would be of any interest but I came across this site browsing around and saw this...
http://artecindustries.3dcartstores.com ... p_183.html- RobD SubscriberRobD started this Subscriber
Good find Kevin!! I need to call them because it looks like they have exactly what I need to get my tie rod higher without going full high steer.....
"kevheb" wrote: Not sure if this would be of any interest but I came across this site browsing around and saw this...
http://artecindustries.3dcartstores.com ... p_183.html__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003So that's a Tie Rod and Drag link together in that kit?
It looks pretty interesting.Kathleen and Brad- RobD SubscriberRobD started this Subscriber
Nope, what I am looking at is going with their high steer arms..drag link will go to the high steer arm and the tie rod will be on heims to their bolt knuckle kit..I would use the configuration in one of the first 4 pictures..
"BKGM Jeepers" wrote: So that's a Tie Rod and Drag link together in that kit?
It looks pretty interesting.__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003What about pic 5 or 6?
