Did you make Back Door, or just pose on it?
Coilover Install
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003I used to wheel a lot. . .
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003Are you running your driver-side tires backwards?
Brad: Yes i still owe dues... i will get those paid shortly...if all works out i will be back in the bayarea next month for good...
John: backdoor is super tough. I gave it several attempts but without a spot to suck down my front suspension with my winch i was on the verge of tipping over. once I stopped and placed it in park to check my line the jeep wouldnt go back into gear, so i winched it up the first part of that waterfall untill it poped into gear and then was able to make it up the rest of the trail unassisted.
All: I need more Hammers, if anyone is interested in putting a trip together anytime I would love to go back....the place is simply amazing - Guest former userGuest former user
"BKGM Jeepers" wrote: Are you running your driver-side tires backwards?
yes the tires are on backwards but i still have tons of traction and really dont want to undo the beadlocks just to switch them around...
It's only about 45 minutes a tire! 😂 ... not true...its 20min to get all the bolts off and then u have to take them down to a tire store to get the back bead off... then to mount them is about an hour a piece once i set up and air up the tires...
