Tom, are you coming on the Rubicon? Is the steering fixed acceptably?
Where did my steering go?
Justin SubscriberJustin SubscriberWe just got Tom all fixed up. He had a cracked pitman arm. 😲 😲 Put a new one on and Tom drove it and says his steering is still not returning to center and his turn signal doesn't self cancel. A quick drag link adjustment and he is all back to normal. 😎 😎
Uhhh...yep...I'm good to go. I will be there on Sunday Morning. I wil be leaving with Subgroup 4A at an unknown time, possibly before noon. Subgroup 4A may be a few LJ's (Bill, Justin, and I). See you all at Buck Island, or when we catch up to you. Channel 10, I sound like Donald Duck.
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003I am subgroup 4b, departing early Monday AM, and meeting everyone at the springs - or sooner!
Are you taking the JK?
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"1tom2go" wrote: Are you taking the JK?
I still need to do three things and wait for my sliders to get here. It looks like Dusy will be run #1, or possibly Triple Trail.
Items left:
re-gear
t-case protection
Evap canister relocationKathleen and Brad- Guest former userGuest former user
Was that drop pitman arm from Rubicon Express? I had the same problem after running Barrett last year. I spun about half the splines off the inside of the pitman. I took it back to RE and they gave me a new one. Talk about a scarry drive home!
- RobD SubscriberRobD Subscriber
About the only good thing Rubicon express makes on any of their lifts is the center belly pan. Everything else either breaks or bends..Sure wish I had gone with a Clayton long arm lift or just went with an all custom lift.
Fred SubscriberFred Subscriber"lj4x4" wrote: Was that drop pitman arm from Rubicon Express? I had the same problem after running Barrett last year. I spun about half the splines off the inside of the pitman. I took it back to RE and they gave me a new one. Talk about a scarry drive home!
Chuck had the same problem with his RE drop pitman arm. About half the teeth were just gone. After inspecting the pitman arm I figured the gearbox shaft had to be toast too but the splines on it were perfect. RE must be using a soft metal for their pitman arms.- Guest former userGuest former user
Yes, it was an RE arm, and yes half of the splines are toast. I know have a Procomp from Justin's Extreme Garage.
glad you got this fixed
