To do list
    #2625 Jun 2008, 8:27 PM
    I got my PS pump taken care of. This one should work better. But, I forgot that I also need to take care of my tie rod ends.
    #2726 Jun 2008, 9:55 AM
    I need to:
    Mount winch and winch plate
    replace battery with an Optima
    Check out stereo wiring, speakers go out when I hit a bump
    Longer front brake lines
    replace rear pinion seal
    replace rear shocks
    front spring coil pads of some sort on the bottom to keep them from scratching against the axle (nasty noise)
    Fix exhaust leak
    mount up spare tire
    Weld up the rest of my beadlocks, switch tires over....
    install tube bumpers
    grease joints
    get doors painted
    That list just keeps getting longer.... 😂
  3. Howdy Subscriber
    #2826 Jun 2008, 2:11 PM
    I just have to get an alignment so I can see what my caster is and install some bumpstops and I will be ready to go.
    I just have to first finish the remodel on the guest bathroom
    Wash and wax trailer, adjust brakes, detail the inside and so some painting on the outside.
    Go on a week vacation.
    Go out of town to a family renunion the next week.
    Start shopping for a new commuter car and get the Expedition ready for sale.
    Go on another week long camping trip.
    Wife goes back to work after summer break and my free time goes back to zero.
    I should have some free time around October to work on the 4runner again 🙄
    #2926 Jun 2008, 2:46 PM
    i forgot what my list would be like. hmmm.... lets start with, go wheeling.
    #3026 Jun 2008, 3:21 PM
    I got the tires cleaned and balanced. That made a big difference but I could still get Death Wobble when I hit pot holes or rail road tracks. Today I switched out my track bar for a better one. Now...NO DEATH WOBBLE 😀
    Now I need to (1).switch springs in the front and (2).finish my rear control arms.
  6. Fred Subscriber
    #3126 Jun 2008, 3:32 PM
    "JohnDF" wrote: Now...NO DEATH WOBBLE 😀
  7. Justin Subscriber
    #3226 Jun 2008, 4:14 PM
    My to do list:
    Build a D60 for the rear.
    Front tube fenders
    Atlas
    Beadlocks
    Probably in that order.
    #3326 Jun 2008, 4:17 PM
    "Justin" wrote: My to do list:
    Front tube fenders
    Atlas
    Beadlocks
    Don't you currently have 15" rims? Will you go with 15" beadlocks, or move up to 17's once you wear these tires out?
  9. Justin Subscriber
    #3426 Jun 2008, 5:04 PM
    "BKGM Jeepers" wrote: [quote="Justin"]My to do list:
    Front tube fenders
    Atlas
    Beadlocks
    I want to move up to 17's if I have bead locks.
    #3526 Jun 2008, 5:37 PM
    Dibs on Justin's 15" tires 😀
  11. Fred Subscriber
    #3628 Jun 2008, 1:21 PM
    Just got back from my shakedown run at Prairie City and need to add a couple things to my to do list.
    - figure out why front ARB isn't working 😢
    - lengthen front swaybar links
    - replace Full Traction rear swaybar with factory rear swaybar (now where did I put that?)
  12. Justin Subscriber
    #3728 Jun 2008, 1:47 PM
    What are the symptoms?
    #3828 Jun 2008, 3:10 PM
    "Justin" wrote: [quote="FAM"]
    It doesn't turn on 🙄
  14. Fred Subscriber
    #3928 Jun 2008, 3:40 PM
    "JohnDF" wrote: [quote="Justin"][quote="FAM"]
    That's pretty much what I know right now. I haven't had much time to check it out. I suspect an electrical problem.
    #4028 Jun 2008, 5:08 PM
    fred. i cant believe you went to PC without me. i drove by that way trying to get the kids to sleep at noon. the funny thing to was i thought id drive by your house since i usually head to folsom after the drive by PC.
  16. Fred Subscriber
    #4128 Jun 2008, 5:14 PM
    "lowrider" wrote: fred. i cant believe you went to PC without me. i drove by that way trying to get the kids to sleep at noon. the funny thing to was i thought id drive by your house since i usually head to folsom after the drive by PC.
    Sorry 😳 I was even there from about 11:30 - 1:00. I could have used a hand too. With my dysfunctional locker I managed to get myself stuck and had a stranger, in a Toyota no less, strap me.
    #4228 Jun 2008, 5:20 PM
    damn. now that really hurts. ok. from now on. post shakedown runs too!!!
  18. RobD Subscriber
    #4328 Jun 2008, 5:53 PM
    To do list
    Stretch the front of my Jeep 5 inches
    40 inch tires
    Cut the back half of the body out and tube it
    Ram assist for the steering
    That should do it for now.
    #4428 Jun 2008, 6:18 PM
    "RobD" wrote: To do list
    40 inch tires
    That sounds cool. See if you can find us a two for one deal. Of course I'll need to stretch the rear too and get a fuel cell in the back. I'll just run mud flaps on the road.
    #4528 Jun 2008, 9:50 PM
    Maybe I'll skip stretching the front. I could just stretch the rear about 8 inches if I comp cut it.
    #4628 Jun 2008, 10:11 PM
    "JohnDF" wrote: Maybe I'll skip stretching the front. I could just stretch the rear about 8 inches if I comp cut it.
    When's the sawzall party?!?!?!?!
    #4728 Jun 2008, 10:34 PM
    "troyman" wrote: [quote="JohnDF"]Maybe I'll skip stretching the front. I could just stretch the rear about 8 inches if I comp cut it.
    When's the sawzall party?!?!?!?!I think it would take more than a sawzall to cut through my Poison Spyder Crusher Corners 😏
    #4829 Jun 2008, 2:38 PM
    "JohnDF" wrote: [quote="troyman"][quote="JohnDF"]Maybe I'll skip stretching the front. I could just stretch the rear about 8 inches if I comp cut it.
    I've got $5 that says you're wrong. Only one way to find out. 😀
    #4929 Jun 2008, 3:13 PM
    I don't want the cut to look like crap. I need a plasma cutter or trade for some comp cut corners. Of course I could use the Sawzall and if it turns out badly I could cut it all off and tube the rear 😎
  25. Fred Subscriber
    #5029 Jun 2008, 3:37 PM
    "FAM" wrote: [quote="JohnDF"][quote="Justin"][quote="FAM"]
    You guys might as well give me a lifetime membership to the Pink Bone award. I figured out why the ARB wasn't working. Before I tell you what was wrong let me give a bit of background.
    I put this ARB equipped axle in about a year ago and have been "using" the ARB when needed and was satisfied with its performance. When I did the wiring and plumbing for the ARB I went ahead and installed switches and solenoids for both front and rear ARB's even thought I still have the Detroit locker in the rear.
    Well . . . 😳 . . . my front ARB never could have been working because I had the switch for the rear ARB hooked up to the solenoid for the front ARB. I always wondered why I never heard the air purging from the line when I turned off the locker. 🙄
