Took off the quick disconnect, added the spring, and added a ground strap from the tire carrier to the tailgate. I have nice low readings below 2.0 again.
CB Tuning
JohnDF SubscriberJohnDF started this SubscriberI used to wheel a lot. . .- buckallred Member Joined: October 2016buckallred Member Joined: October 2016
FYI. This gizmo supposedly allows you to lay your antenna down temporarily. I'm thinking about getting one.
https://www.wearecb.com/lift-and-lay-stud-for-cb-antennas.html
Jeff_R Member Joined: October 2016Jeff_R Member Joined: October 2016JohnDF said Took off the quick disconnect, added the spring, and added a ground strap from the tire carrier to the tailgate. I have nice low readings below 2.0 again.
I use a quick disconnect on mine. Anytime I go wheeling with my antenna on or with a box on my rack, I take my garage door remote control out of my Jeep so I don't forget and drive into the garage and damage something.
Haha. That's exactly why I wanted the spring, just in case I forget.
