Fordyce..6/27/09
    #5124 Jun 2009, 4:27 PM
    Haven't tried again yet. Got another temporary so I'm good through the end of August right now. I'm fully paid up, just have to run one of those red sticker deals until I can get it to pass. I'm going to try running it for about 30 - 45 minutes on the freeway and then take it in to see how it does. It's been sitting so long, that's it not really that surprising that it doesn't pass.
    #5224 Jun 2009, 9:06 PM
    Just finished tuning up my Jeep. The tune-up was long overdue. Changed the oil, spark plugs, and threw in a Firepower ignition kit. It's running smoooooooth. Also double checked the suspension and greased all the zerks. I'm ready for Saturday! πŸ˜€
    #5324 Jun 2009, 9:19 PM
    Can't wait 😎
    #5424 Jun 2009, 9:30 PM
    "FAM" wrote: [quote="JohnDF"]But, I think Fred is going to have an open seat. Stay tuned.
    I'm out for this weekend. I took out a tire on Rubicon and won't have time to get it replaced in time for this trip. 😒
    Fred You can borrow my spare. My lug pattern is 5 on 4.5. I have to work this weekend and I wont need it.
  5. RobD Subscriber
    #5524 Jun 2009, 9:33 PM
    Don't talk like this around John, he thinks his Jeep will break if he changes any oil, greases zerks, or washes it..I am betting he still has the same engine and tranny oil that he did when he bought his Jeep πŸ˜‚ πŸ˜‚ πŸ˜‚ πŸ˜‚ πŸ˜‚
    I conned him into washing his Jeep one time, and we drove to the car wash and he commenced to power washing the inside of his Jeep, seats, dash, inside of the drivers window, etc 😲 😲 There was like 5 inches of water on the floor board as we drove back to his house and my seat was soaked 😈 😈
    "kevheb" wrote: Just finished tuning up my Jeep. The tune-up was long overdue. Changed the oil, spark plugs, and threw in a Firepower ignition kit. It's running smoooooooth. Also double checked the suspension and greased all the zerks. I'm ready for Saturday! πŸ˜€
  6. Fred Subscriber
    #5624 Jun 2009, 9:41 PM
    "lj4x4" wrote: Fred You can borrow my spare. My lug pattern is 5 on 4.5. I have to work this weekend and I wont need it.
    Thanks Bill, but I also need to do some diagnostics on my brakes. Tuesday morning leaving Buck Island they didn't feel right. I adjusted my proportioning valve to get more rear brake and that helped but didn't completely resolve the issue. I think I may need to replace the master cylinder again. I suspect the hydraulic brake booster may be putting too much pressure on the Corvette master cylinder(s) I've been using.
    #5724 Jun 2009, 10:08 PM
    "RobD" wrote: Don't talk like this around John, he thinks his Jeep will break if he changes any oil, greases zerks, or washes it..
    3 years at the Hammers and no breakage 😏 The old grease, oil, and dirt is holding it all together 😁
  8. RobD Subscriber
    #5824 Jun 2009, 10:21 PM
    Not sure what is wrong with your hydroboost, but I have been running mine for 4 years of hard wheeling and a lot of street driving on 37's and now 40 inch tires and my brakes still work like a champ and even lock up my 40's!
    "FAM" wrote: [quote="lj4x4"]Fred You can borrow my spare. My lug pattern is 5 on 4.5. I have to work this weekend and I wont need it.
  9. Fred Subscriber
    #5924 Jun 2009, 11:17 PM
    "RobD" wrote: Not sure what is wrong with your hydroboost, but I have been running mine for 4 years of hard wheeling and a lot of street driving on 37's and now 40 inch tires and my brakes still work like a champ and even lock up my 40's!
    If I remember correctly you're running the Chevy 1 ton truck master cylinder (rectangular cover). I've installed the smaller Corvette master cylinder (oval cover). When it works correctly the peddle is a little softer than with the C30 master cylinder. My first hydroboost that was damaged during shipping had the Corvette master, but the replacement had the C30 master. Van said some people had trouble with the Corvette master cylinder but didn't elaborate. I've still got the bigger C30 master cylinder and will probably just switch to it and see if it holds up longer.
  10. RobD Subscriber
    #6024 Jun 2009, 11:23 PM
    Mine is the square top, the only issue I do have is leakage of power steering fluid, not sure where that is coming from, maybe the remote res., or loose bolt, not sure, but as far as brakes go it has done a great job, I don't run a proportioning valve though.
    #6125 Jun 2009, 10:19 AM
    Looks like I'm gonna make this one. 😎 Alex???
    #6225 Jun 2009, 10:25 AM
    Glad to hear it 😎 I'll need help getting Rob's rig off the trail πŸ˜‚
    #6325 Jun 2009, 12:41 PM
    "Bender" wrote: Looks like I'm gonna make this one. 😎 Alex???
    really? +1 or alone? I'm still working on it. Not very optimistic tho. 😳
    #6425 Jun 2009, 12:54 PM
    Just finished welding up a cracked bracket, man it's time to go coilover..... Getting to that bracket was a pain in the @ss!! 😀
    Left to do:
    Put the driver front coil back in
    Reconnect the driver upper control arm (new bolt)
    Three bolts in the passenger side rocker
    new front diff cover bolts (on the way to the store now)
    Fill the front diff
    Check various bolts / u-joints
    Spread some silicone on my front two wheels for the beadlocks (or maybe find the pinhole leak in the welds)
    Drink 🍺
    start loading up the rig for Saturday
  15. Fred Subscriber
    #6525 Jun 2009, 5:01 PM
    Don's anticipating going.
    #6625 Jun 2009, 5:59 PM
    Is Don prepared if we go further, like over Winch Hill #1?
    Winch Hill #1 was pretty tough last time I ran it and Rob says it's even harder this year.
  17. Fred Subscriber
    #6725 Jun 2009, 6:16 PM
    "JohnDF" wrote: Is Don prepared if we go further, like over Winch Hill #1?
    That's a good question. I don't know. He said he read the description on the calendar and was anticipating going. His Jeep does have front & rear ARB's so the Jeep should/may be capable enough. I don't think he's ever seen winch hill 1 so I can't really ask him if he thinks he's ready for it. Any idea how the WH1 bypass is these days?
    If the requirements for the run have changed let me know and I'll pass that on to Don.
    #6825 Jun 2009, 7:03 PM
    No, the requirements are the same. And we probably won't get to winch #1 anyways. We'll play it by ear and take what comes. But you know as well as anybody that Fordyce can reach out and bite you πŸ˜‚
    This run was set up for just this purpose. To get some new guys introduced to the best local trail. We will only go as far as people feel comfortable.
  19. Fred Subscriber
    #6925 Jun 2009, 7:20 PM
    "JohnDF" wrote: This run was set up for just this purpose. To get some new guys introduced to the best local trail. We will only go as far as people feel comfortable.
    Ok, thanks for the update. He said he'd have to see how he felt that morning so who knows whether or not he'll be up to it, but he'd like to go. I read him the meeting location, 7:30 at Sweet Peas and 8:30 at Starbucks. He sounded like he was planning on the Starbucks location. I'm not sure I'd wait on him too long. You may want to check the contact info forum and get his cell phone number.
  20. k-jeep Member Joined: May 2009
    #7025 Jun 2009, 8:00 PM
    For the meeting location, where is the Starbucks :?:
    #7125 Jun 2009, 8:03 PM
    Right next to Bakers Square πŸ˜‚
    Hwy 80 to the Forest Hill exit. Turn right at the light and right at the next light. It's just up on the right side, you should be able to see it from I80. Call my cell phone if you get lost.
  22. RobD Subscriber
    #7225 Jun 2009, 8:06 PM
    Boy, 7:30 am breakfast sure scares a lot of people πŸ˜‚ If two old guys like John and I can get up that early, everyone else should. Keane has no excuse, he is like 21 years old πŸ˜€
    #7325 Jun 2009, 8:48 PM
    "RobD" wrote: Boy, 7:30 am breakfast sure scares a lot of people πŸ˜‚ If two old guys like John and I can get up that early, everyone else should. Keane has no excuse, he is like 21 years old πŸ˜€
    Yummmm... Sweetpeas.... I'll be there for sure!
    #7425 Jun 2009, 9:13 PM
    I'll probably be there for breakfast. The baby gets up around 5. πŸ™
    #7525 Jun 2009, 9:41 PM
    We've heard from everybody but Mark and Justin...
