Strawberry Fall Maintenance Run 1 of 2 - 9/28/25
  1. Folsom4Rnr (Brian) Member Joined: April 2019
    #2627 Sep 2025, 1:20 PM
    Ok I got the other 4Runner ready and will see ya all tomorrow morning.
    #2727 Sep 2025, 3:43 PM
    Dang something came up and I'm unfortunately unable to make it tomorrow. See everyone on the next Sunday ANYTHING
  3. Folsom4Rnr (Brian) Member Joined: April 2019
    #2828 Sep 2025, 11:41 AM
    Off trail. Stopped for a quick appy and beverage at Solid Ground and now home and in packed.
    Was a nice day out on trail.
    #2928 Sep 2025, 11:00 PM
    I got home around 4:30pm. Thank you Brian for your excellent leadership!!
  5. Jeff L Member Joined: October 2023
    #3029 Sep 2025, 6:12 AM
    Great trial run.  Our trial looked pretty clean.  Thanks for Brain and Brad for leading.  Cookies and bread were delicious!!  Thanks for the treats!
    #3129 Sep 2025, 7:25 AM
    I got home at about 4:15 with some apple hill traffic.
    A couple of trail observations:
    Very little trash
    Very little brush cut back - there were/are some overhanging branches that can be cut back.
    There are lots of logs lining the trail, and many that narrow or slightly re-direct the trail.  These need to be dealt with.
    We did cut logs partially re-directing the trail on the back side of the trail.
    Strawberry Canyon Rd needs some help!
    We counted at least 3 culvert pipes that are completely clogged - resulting in creek flows across the road and erosion.  These need to be dug up with shovels and pick axes. -
    We cut down/removed a hanging snag tree on Strawberry Canyon Rd.  Pay attention to your surroundings.  Some are quite dangerous.
    In speaking with our sub-group, I think we may need a committed saw-cutting effort to shorten logs so they can be physically moved.
    Also, if Kris can get his mini excavator to Strawberry Canyon Rd. and clear the culverts before winter as a separate maintenance effort, or on the third run?  This is not up the 4wd trail.
    The kiosks need work.  The strawberry side needs a need cross-support bracket brought up., and ensuring the roof is re-aligned.  This is fairly simple.
    The 88 side needs a ground brace to stabelize it, re-painting, and the roof realigned.
    Both the hard signs need new decals for both the USFS and the club.
    Does anyone see other improvements I missed?
    #3230 Sep 2025, 4:30 AM
    Just a pic of the 88 side kiosk.
  8. Chris Campbell Member Joined: August 2019
    #3330 Sep 2025, 3:51 PM
    With regards to Kris and the excavator work, if you do go up on a random weekday let me know.  I typically have more weekdays free than weekends this time of year.  I might be available for coming up for the day to help with some grunt work as your tractor does the big stuff.
    Chris Campbell
    #341 Oct 2025, 12:17 AM
    Chris Campbell said With regards to Kris and the excavator work, if you do go up on a random weekday let me know.  I typically have more weekdays free than weekends this time of year.  I might be available for coming up for the day to help with some grunt work as your tractor does the big stuff.
    With some notice I can help as well.
  10. Folsom4Rnr (Brian) Member Joined: April 2019
    #357 Oct 2025, 1:49 AM
    BKGM Jeepers said I got home at about 4:15 with some apple hill traffic.   A couple of trail observations: Very little trash Very little brush cut back - there were/are some overhanging branches that can be cut back. There are lots of logs lining the trail, and many that narrow or slightly re-direct the trail.  These need to be dealt with. We did cut logs partially re-directing the trail on the back side of the trail. Strawberry Canyon Rd needs some help! We counted at least 3 culvert pipes that are completely clogged - resulting in creek flows across the road and erosion.  These need to be dug up with shovels and pick axes. -  We cut down/removed a hanging snag tree on Strawberry Canyon Rd.  Pay attention to your surroundings.  Some are quite dangerous.   In speaking with our sub-group, I think we may need a committed saw-cutting effort to shorten logs so they can be physically moved. Also, if Kris can get his mini excavator to Strawberry Canyon Rd. and clear the culverts before winter as a separate maintenance effort, or on the third run?  This is not up the 4wd trail.   The kiosks need work.  The strawberry side needs a need cross-support bracket brought up., and ensuring the roof is re-aligned.  This is fairly simple. The 88 side needs a ground brace to stabelize it, re-painting, and the roof realigned. Both the hard signs need new decals for both the USFS and the club.   Does anyone see other improvements I missed?
    We noted a few places it looks like people might be trying to create by passes and a few water spots we might want to keep an eye on. I sent Kris pictures with location info in metadata for our report out.
  11. Folsom4Rnr (Brian) Member Joined: April 2019
    #367 Oct 2025, 2:01 AM
    Some of the non-maintenance-business pix of the Posse... Was a great day with everyone. Thanks Stacey, Kelly and Jeff for the treats!
