Found the caliper bracket bolts I needed, $6 a piece😠
Should have some e-brake cables to try by friday, thanks Kevin!🍺
Total price has climbed by another $84 to cover the caliper bolts, rear brake hard lines, and a 1/4 NPT tap for the rear axle vent. Was able to use some TJ Dana 44 rear hard lines that come pre-bent and with the short hose for the disc brakes. Made rear brakes nice and easy after adding a few custom bends. The 35 housing in my junk pile had already been harvested for the vent and hard lines for the 8.8 build so I had to go new with both.
