I am planning on putting a 14 bolt in the rear of my JK. I am slowly gathering the needed parts watching craigslist and such looking for the perfect 14 bolt donor axle.
So far I have the following:
Control Arm/ Trackbar Brackets - Ruff Stuff
ARB Locker - EBAY (Brown Santa deliverd it today!) Saved about $400 dollars and its new!
Needed:
donor axle
Diff Cover/Shave Kit??
Disc Brake Conversion Kit
Hubs with 5x5.5 bolt pattern or new rims with 8 lug pattern.
Bearing Kit
5.38 Gears
Not in a great rush, but would like to have it by MOAB next year.
14 Bolt rear axle build.
huck271 Subscriberhuck271 Subscriber
huck271 Subscriberhuck271 started this Subscriber
Jeff- that guy with the foolsize SubscriberJeff- that guy with the foolsize SubscriberWhy 5on 5.5? You are 8 lug.
Jeff- that guy with the foolsize SubscriberJeff- that guy with the foolsize Subscriberhttp://www.solidaxle.com/ProductCart/pc ... ategory=11
Solid axle industries has them for $400
huck271 Subscriberhuck271 started this SubscriberI'm actually 5 x 5.5 currently so there are two options.
Option 1: I get the SolidAxle hub that converts to 5 x 5.5. The challenge in doing this is retaining an emergency brake setup.
Option 2: I switch to 8 lug. This would be the easiest but the most costly as I would need to get new rims. It would also cause my front and rear rims to be different patterns unless I convert my front axle to 8 lug as well.
Option 1 is much cheaper but Option 2 may be the best long term solution.
Jeff- that guy with the foolsize SubscriberJeff- that guy with the foolsize SubscriberJust use the solid hubs and use a ruff stuff disk brake bracket with the Eldorado calipers. Done.
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009What about wheel adapters until you can do the conversion?
That's what I'm planning for my rear D44. My new front will be 8-lug. I have to wait a little longer to swap the rear.
I don't know much about them but these look interesting: Torq Axle.
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003Well that's more than I had planned to spend on my rear! Do all the electronics work with that set up?
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009"BKGM Jeepers" wrote: Well that's more than I had planned to spend on my rear! Do all the electronics work with that set up?
Yeah, those are pricey as a complete axle. Not sure about the electronics or if they just sell the housing for his application.
I'll be going D60 for my rear axle since I don't have a Hemi and 40s. 😁- Guest former userGuest former user
Check out ruffstuff. They have a similar set up but in a high pinion.
http://www.ruffstuffspecialties.com/cat ... SOLID14CAT - Guest former userGuest former user
Pretty sure all drop out Super 14's are low pinion. Mark
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"lj4x4" wrote: Check out ruffstuff. They have a similar set up but in a high pinion.
Does it look like they build a complete set up that is electronics compliant. I like the clearance and would probably pay extra for the 1.5" and 100+lbs weight savings.Kathleen and Brad
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003Looks good! Please post up your progress!
Josh Subscriber- Guest former userGuest former user
Did you find that the Dynatrac tone rings for 60/70 will work just by turning the ID out a tad for the 14 bolt?
