what's your list of stuff to build in the coming year?
buying it doesn't count.
2009 fabrication resolutions
Dan-H SubscriberDan-H SubscriberClosed Mondays.- Guest former userGuest former user
- Roll cage (new tube bender under the Christmas Tree)
- Radiator/Grill Hoop
- Storage Racks
- Top mounted spare tire, or raised in the tub - I like having the full view behind me and don't want to give it up.
- Redo the frame, rear link mounts and spring mounts
- D60 to replace the 9"
- Switch to 8 lug and beadlocks (weld-on)
- Engine swap
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003Track bar brace
Rear flares
Tow bar attachmentsI used to wheel a lot. . .
Justin SubscriberJustin SubscriberI just want my Jeep on 4 tires again. 😳
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003"Justin" wrote: I just want my Jeep on 4 tires again. 😳
So you can get it back on two tires again 😲
I will build a york bracket to fit a 22re so I can be cool like John. Well, at least a Toyota driving version of John. 😂
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003"Bender" wrote: I will build a york bracket to fit a 22re so I can be cool like John. Well, at least a Toyota driving version of John. 😂
Wouldn't that make you "cooler" than me?
I have the welder, drills, and cutting tools if you need help on the bracket. Get the design and we can make you one.__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan - Guest former userGuest former user
"RobD" wrote: [quote="Bender"]I will build a york bracket to fit a 22re so I can be cool like John. Well, at least a Toyota driving version of John. 😂
Thanks for the offer, I've actually been working with a guy from work. We drew it up on this program he has and checked tool clearances. He used to weld for a living. I'm not sure what he was working on, but his welds had to meet tolerances in the thousandths of an inch. We may have to make more than one. 😉 If that doesn't work out, I'll be in touch. CO2 is too expensive up here! - Guest former userGuest former user
new sliders with side hoops
redo the front rock-lights
redo underhood lights
rear shocks...done 😉 - Guest former userGuest former user
i want to move my gas tank up a few inches.
i want to remove my low hanging bracket in the rear that connects the lower control arms. i just dont know if its possible to get longer arms or it i have to fab one up. maybe make an adjustable control arm link with heim joints?
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003I'll be working on some rock light adjustments and probably do some rear suspension work on the yellow jeep.
