A question for you TJ and LJ owners
  1. Tom Subscriber
    #126 Dec 2013, 4:27 AM
    In all of your modifications, would any of you still have your stock height rear coil springs tucked away. Please let me know.
    Don't ask any questions yet, but this is the fabrication section.
    #227 Dec 2013, 12:26 PM
    I might have some springs. Not sure if they are stock or not. I'll check and get back to you.
  3. BLTJeep Subscriber
    #327 Dec 2013, 12:47 PM
    I will look... I have no idea if they are still down in the lower garage... Will check tomorrow.
    Brian
  4. Tom started this Subscriber
    #428 Dec 2013, 2:24 AM
    Thanks guys. From what I've read, the "stock" rear TJ coils under the XJ will allow me to remove my 2" spacer on the front coil.
    #528 Dec 2013, 5:14 AM
    Mine are long gone, but I do have two rear stock coils out of the ram express.
  6. JohnDF Subscriber
    #628 Dec 2013, 5:27 AM
    Don't see how that can be true? The rear coils in a TJ are shorter and fatter than XJ or TJ front coils. I'm perplexed.
  7. Tom started this Subscriber
    #728 Dec 2013, 6:45 AM
    They'd be going under the rear between axle and subframe so, yes, they will be shorter than front coils.
  8. JohnDF Subscriber
    #828 Dec 2013, 6:59 AM
    TomD said
    They’d be going under the rear between axle and subframe so, yes, they will be shorter than front coils.
    So you’d link the rear and use the stock TJ rear springs? Or is your rear already linked?
    That makes more sense to me now. Thanks for clearing that up.
    So you're looking to lower the rear? Then you can remove the front spacer and lower the front?
  9. Tom started this Subscriber
    #928 Dec 2013, 7:03 AM
    Something tells me that coming down on those hard might launch me through the windshield. Their spring rate is about double that of the stock XJ.
  10. Tom started this Subscriber
    #1028 Dec 2013, 7:05 AM
    That's the plan. So far the numbers are working out and the upper and lower CAs are in route.
    I'll start a build thread as soon as it all comes together.
    So you'd link the rear and use the stock TJ rear springs?
  11. JohnDF Subscriber
    #1128 Dec 2013, 7:07 AM
    Sounds like a fun project.
  12. Tom started this Subscriber
    #1228 Dec 2013, 7:20 AM
    Among other things, I'll be looking for input. Stay tuned.
  13. David & Lori Member Joined: January 2013
    #1329 Dec 2013, 11:21 AM
    But i think You should wait to 🔥 until late April early May to make it a official spring mod …. 😉
  14. Tom started this Subscriber
    #1429 Dec 2013, 1:21 PM
    Specialsoundman said
    But i think You should wait to [https://posse4x4.org/wp-content/sp-resources/forum-smileys/icon_weld.gif] until late April early May to make it a official spring mod …. [https://posse4x4.org/wp-content/sp-resources/forum-smileys/sf-wink.gif]
    I'll be assembling bits and pieces for a bit. No rush.
