Guest former user
Guest former user
The upper front control arm frame mount. Is there any reason to cut that off or leave it ? (Refering to a tj.) Figured if I have the grinder out.............. :hack:
Flex it out and see if it binds. If so, it's gotta go!
Thanks. Does not hit on the flex.
You can test it on Strawberry Maintenance run, can you make it?
