Good Rolling Floor Jack for my shop
  1. Sharkbyte Subscriber
    #17 Dec 2016, 10:31 AM
    This past weekend I picked up a 3 ton floor jack from Harbor Freight for $68 on a holiday deal.  Do I need more than a 3 ton jack?  The max jack height is 20".  Is that enough lift?  They had a fancy Daytona Jack for $179 that had a max height of 23" and a 3 ton limit.   The Daytona Jack seemed like a lot of money right up to the point you are trying to work on you suspension and you need 3 more inches...
    Any thoughts would be appreciated.
    Thanks!
  2. Mike G Subscriber
    #27 Dec 2016, 11:14 AM
    When needing more height I just use 4x4 blocks with the jack
  3. Darrell and Jill Subscriber
    #37 Dec 2016, 11:38 AM
    Sharkbyte said This past weekend I picked up a 3 ton floor jack from Harbor Freight for $68 on a holiday deal.  Do I need more than a 3 ton jack?  The max jack height is 20".  Is that enough lift?  They had a fancy Daytona Jack for $179 that had a max height of 23" and a 3 ton limit.   The Daytona Jack seemed like a lot of money right up to the point you are trying to work on you suspension and you need 3 more inches...  Any thoughts would be appreciated. Thanks!
    Really, you bought a jack from there, your seals might blow out.
    #47 Dec 2016, 1:09 PM
    I've owned two harbor freight jacks.  Both worked great.
  5. Josh Subscriber
    #57 Dec 2016, 1:22 PM
    Sears has some good floor jacks. I have two 5ton jacks I bought there. One I bought over a decade ago. They work great. Never had a problem.
    #67 Dec 2016, 1:34 PM
    Just make sure you have jack stands in place when you are under your vehicle!
  7. Sharkbyte started this Subscriber
    #78 Dec 2016, 2:12 AM
    Jeff_R said Just make sure you have jack stands in place when you are under your vehicle!
    Absolutely!  I will pick up some 6 ton jack stands before I ever go under my Jeep.  Thanks !
  8. Darrell and Jill Subscriber
    #89 Dec 2016, 3:25 AM
    Josh said Sears has some good floor jacks. I have two 5ton jacks I bought there. One I bought over a decade ago. They work great. Never had a problem.
    That's what I have, 20 + years and counting.
    #910 Dec 2016, 4:11 AM
    I have 12 ton stands to reach the frame, 6 ton stands for under the axles, and 3 ton stands because it was the first set I bought.
  10. scoped Subscriber
    #1010 Dec 2016, 1:56 PM
    Get the 12 ton ones to reach the frame
