Limit Straps
    #116 Nov 2010, 8:29 AM
    Anyone know of any informative tech articles ? My swaybar stops the axle before the shocks top out in the F&R,so I think the shocks are safe for now. Want to lengthen the links in the rear to move the roll center ( on road issue ) but then the shocks will stop the axle at full droop, I've bent a few. In the front I may have gone a bit too far with the flex thing. Have driven on the beadlock ring and it felt like it was going to flop with most of the tires on the ground. Some refer to this as the 'slinkey thing ". I saw John carry a front tire over something that mine would have dropped into and he made it look easy. No way would I have taken that line. It would have been a disaster. It just got me thinking, should I make a change ? The bumpstops were set by pulling all the springs and dropping it under its own weight with shocks on,so I plan to leave them alone. CV's and front DS notch in belly pan clearanced and checked at full droop with links off so I think it's ok there. The shops I've talked to have said to set them 1-2 inches short to allow for stretch and put the mounts where you can. Just looking for more input and info before I do it.
    #216 Nov 2010, 12:32 PM
    My shocks are my limiting straps 😁
  3. Justin Subscriber
    #316 Nov 2010, 2:38 PM
    "JohnDF" wrote: My shocks are my limiting straps 😁
    x2 😁 😳
    #416 Nov 2010, 3:37 PM
    X3, including my coil overs when I disconnect my sway-loc.
  5. RobD Subscriber
    #516 Nov 2010, 4:24 PM
    X4 -- and I only have 6 inches of down travel and 5 up travel and I get more flex than I need.
    #616 Nov 2010, 4:30 PM
    Oh ya...and my Currie Antirock allows for controlled flex while being able to...Haha...I could almost keep a straight face when I say that...Getting so close...Blaine would be proud πŸ˜‚
    #717 Nov 2010, 5:57 AM
    Haven't had much luck with the bilstein's as limit straps. The shafts like to bend, turn blue then leak. Have got some RE and WE reservoir shocks that have less comp dampening than the bilstein's. Guess I will try that in front along with the teraflex dual rate. They were supposed to be for the green jeep but she has not put them on yet so....... I'm off to visit a nitrogen bottle.
    #817 Nov 2010, 6:20 AM
    Rob and I, and others I believe, have had the same luck with the Bilstein shocks. Man, they are sweet when you first put them on, but they break down quickly. I'm sticking with the cheap gas-charged ProComp shocks from now on. They are indestructable, if you can handle the stiff ride quality.
    #917 Nov 2010, 6:35 AM
    Mine have been fine since i don't let them top or bottom anymore. Sue's has had pro-comp shocks on for about a year now. They were a huge improvement over both sets of rancho's.
