anybody have a welder and torch
goin cheep on the rear axle til i find 8.8 or get my TJ down here
and how much would you charge me to do it
i dont mind getting dirty and would help 110%
i just dont know how to weld yet
lincoln lock
no one
dont really want to buy a locker for a dana 35
and the tj has a dana44
im hoping to go 8.8 with the xj
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003I'm not a fan of Lincoln lockers. I'd rather put a decent locker in the front if I was getting rid of the rear.
Tom SubscriberTom SubscriberAs flexy as the axle tubes are on the D35, I'm not sure how long the rear end would last with a Lincoln locker or spool (neither has differentiation).
After doing a quick web search, the general consensus is to carry extra axles.
brains on slow
never even thought of doing front first
brain must be on pause
Tom SubscriberTom SubscriberIn all seriousness, I'll be installing a D44 in the rear of my XJ in late January which will make a C8.25 available if you're interested.
Just redid the brakes and wheel cylinders. Also raised the shock mounts last year for more clearance.
TJ already has dana 44
goin with ford 8.8 with the XJ
thanks anyway
