Giving it a whirl.
Still working out the dims.
More air
BKGM Jeepers President Joined: June 2003
Tom SubscriberTom SubscriberRight on!
What position are you going to mount it? Mark
Outboard of the alternator similar to this:
Or set it down further:
Not final yet. Some water jet quotes have been on the high end that is slowing me down. Awaiting some other feedback. Bracket design is draft. I want to run it with vbelt which will need combo pulley so I can stick with stock serp belt. - Guest former userGuest former user
Cool, mounting it vertical means you don't have to worry about discharge side. I'm guessing a 9 or 10 series? Mark
The curved slots are what handle the tensioning the belt.
Will use my existing 5 gallon tank underneath. - Guest former userGuest former user
One set cut and hope they are dialed.
