I found a 2011 3.6L Mopar motor with 10K miles for $1300. It lists the 6-speed manual as direct bolt-in. Can anyone confirm this? I'm having difficulty verifying my transmission is a match (08, JKU). Also, it looks like all my accessories are a direct swap over, leaving my outstanding questions all related to the ECU and whether I can simply remove my old one and put in the new one - and plug it in. Thoughts???
Motor question
Fred SubscriberFred SubscriberI thought the new engines didn't come out until 2012? Isn't the 2011 the same as your 2008?
scoped Subscriberscoped SubscriberIs it a jk motor or a charger/300
I would be extremly surprised if the ecu was a direct plug in but if so that's nice.
I thought I read or heard somewhere the gearbox was the same just different gear ratios. If it's not a direct bolt up It could possibly just be a bell housing and or input shaft? - are the flywheel part#s the same? Clutch kits same or diff?
BKGM Jeepers President Joined: June 2003BKGM Jeepers started this President Joined: June 2003It's not out of a JK. It's out of another dodge vehicle! It is still the same hp and torque numbers.
scoped Subscriberscoped SubscriberBe cautiouse there may be alot of things you need to change - manifolds, pulleys, dip stick locations , I'm assuming it's a rear drive application 3.6? If it's a front drive application I don't know how much they change mounting locations motor mounts and junk?
I would not do one unless it was out of a jk without some serious research first to make sure it's alike - not that it can't be done but if there are a ton of differences it could turn into a real pain.
However if you do it I would really like to be involved
BKGM Jeepers President Joined: June 2003BKGM Jeepers started this President Joined: June 2003It's out of a fwd van.
I know the motor mounts would change plus other stuff.Kathleen and Brad- Guest former userGuest former user
Whats a 3.6 fwd van motor got to do with a Hemi ?
BKGM Jeepers President Joined: June 2003BKGM Jeepers started this President Joined: June 2003"rick-rock" wrote: Whats a 3.6 fwd van motor got to do with a Hemi ?
Poor mans hemi. 2000 project vs a 12000 project.Kathleen and Brad- Guest former userGuest former user
"BKGM Jeepers" wrote: It's not out of a JK. It's out of another dodge vehicle! It is still the same hp and torque numbers.
Same hp and torque numbers as what? The new JK?
huck271 Subscriberhuck271 SubscriberIt would make more sense to do a supercharger.
This not a hemi replacement. There is no replacement for displacement.
