I helped Rob a little this weekend high lining his front fenders. All I can say is that there is no way to fit a 40" tire in a Jeep wheel well. Even with the high line fenders, which is like adding 3 more inches of lift, the tires are going to rub. Don't even think about fitting them in the back without comp cutting. Those are some monster tires :hack:
40 tires
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003I used to wheel a lot. . .- Guest former userGuest former user
π
:worthless:
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003Pics? You're asking the wrong guy. Hopefully Rob will post some. Those tires look awsome π
Thanks for the hekp John and Troy. I still have a few more things to relocate under the hood, but I welded up some new battery brackets today and got the battery back in and hooked up.. John, want to bet that I can make those tires work without comp cutting π
Non comp cut rig running 40's with the same 4.5 lift and stretch I am running
__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan - RobD SubscriberRobD Subscriber__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003Those pictures also show front fenders that aren't high-lined...and we saw how well that was going to work π
Your tires are bigger than those 40s shown in those pictures. But, I hope it works because if I win the lottery, I'd want to do it too.I used to wheel a lot. . .- Guest former userGuest former user
"JohnDF" wrote: But, I hope it works because if I win the lottery, I'd want to do it too.
Win or do not win. There is no if. π
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003Okay Master [Toy] Yoda... π
I'm really bummed they aren't making a 37x15 MT/R π
Looks like my future tire may be an Irok.I used to wheel a lot. . .- Guest former userGuest former user
"JohnDF" wrote: I'm really bummed they aren't making a 37x15 MT/R π
x2. Maybe if we write a letter they will make them. π
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003I'd say we can start a Posse letter writing campaign, but it's like pulling teeth just trying to get these guys to write on this forum. This place is slooow π€ and it's wheeling season.
You don't think a two person letter campaign would be very convincing? π
Why don't you guys write someone a letter convicing them to by my Dana 44 π
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003Nobody wants to run a Dana 44...they break π
If anyone comes accross a 1978 or 1979 Ford high pinion dana 60, let me know. I am in the market for one!!!
"RobD" wrote: If anyone comes accross a 1978 or 1979 Ford high pinion dana 60, let me know. I am in the market for one!!!
I have an 89. π
"RobD" wrote: Thanks for the hekp John and Troy. I still have a few more things to relocate under the hood, but I welded up some new battery brackets today and got the battery back in and hooked up.. John, want to bet that I can make those tires work without comp cutting π
Any time, thanks for letting me use the welder - I'll bring you by a new roll of .035 :rasta: - RobD SubscriberRobD Subscriber
High lining the fenders is nice once it is all done, but let me warn you, it is not an easy job. You have to relocate the battery, all of your emissions canisters, and several other items. My windshield washer fluid is gone forever. There is no where to put it. Tools you will need are a welder, plenty of scrap metal to make all new brackets, cutting tools, drills, grinders, and a lack of common sense. This is the last high line fender job I am doing. It has taken three days and I still don't have it all back together. If you run a big air compressor under the hood, you won't after you do this. The only compressor that fits under the hood now is an ARB compressor. Not sure what I am going to do with my βExtreme airβ compressor I took out. Probably sell it.
This is only ΒΌ of what I still need to do to make the 40βs fit with only 4.5 inches of lift.__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan - Guest former userGuest former user
So what's the final verdict on the back? Comp cut or open the wheel well further? :hack: You already know the route I'd take π
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003"RobD" wrote: Tools you will need are ...a lack of common sense. .
Or a friend with a little common sense to keep you from cutting out bubbles and inner fenders. Just lift it up with straps π
i want 40inch tires too. ugh. i forgot i need to buy bumpers first. π
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003I want 40" MT/Rs too...Ugghh...I forgot, I can't afford it π’
Justin SubscriberJustin SubscriberI don't want 40" tires. I'm not hardcore enough. π
37's will do just fine. π
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003When I can't follow Rob, then I'll look into 40s...
However, his Little Sluice attempt this year will be tainted πI used to wheel a lot. . .- RobD SubscriberRobD Subscriber
I wouldn't bet on me running LS this year unless it is in your Jeep. I somehow doubt I will be wheeling my Jeep until this time next year π
"JohnDF" wrote: When I can't follow Rob, then I'll look into 40s...
However, his Little Sluice attempt this year will be tainted π__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003"RobD" wrote: I wouldn't bet on me running LS this year unless it is in your Jeep. I somehow doubt I will be wheeling my Jeep until this time next year π
I've heard that before π
