I have used Keith’s alignment in Diamond Springs for almost two decades but they have closed. Where do you guys take your stuff. Seems like the average shop can only put it on a rack and deal with factory numbers. I need a guy that can field a discussion of how it is handling and what needs to happen to get it working right even if it's not all factory parts.
Alignment shop
Mash5boom SubscriberMash5boom SubscriberMark ~ KJ6EUO
JigglyJr Member Joined: August 2020JigglyJr Member Joined: August 2020I know Linville Bros on El Camino is Sacramento can do 4x4 alignments. They did the alignment on Dads JK and did a good job.
my personal favorite is doing a "redneck" alignment in the garage with angle iron and ratchet straps
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003You can go to/ask CloakWorks 4x4 (Extreme Gear), since they've moved your direction. They are off of Greenstone.
They have lots of experience with front end geometry and modified suspension/steering.
Howdy SubscriberHowdy SubscriberClark Frame in Roseville. Its where you go when every other alignment shop does the best they can and you want it better.
