Hi:
I have one of these:
ARB ARB505 E-Z Deflator, Orange https://www.amazon.com/dp/B004LQCDOA/ref=cm_sw_r_cp_apa_i_tZr8AbME0M3HR
The problem is that it doesn't work. When I thread the thing onto the outer valve stem threads, the plunger part is supposed to grab the actual valve stem core and unscrew it (removing the stem), so then you can slide the mechanism forward and backward to quickly let air out and check the tire pressure. For mine, the plunger does not grab the valve stem. The end of the plunger appears to have/be a slotted mechanism, while the valve stem appears to be perfectly round. So the plunger doesn't have the ability to grab and rotate the valve stem like a screwdriver.
At first I thought that maybe my tires and rims were so old that I had some sort of obsolete/ancient valve stems. Since then I've replaced the tires and rims and valve stems. The thing still doesn't work.
I've done some Googling and apparently I'm the only person on the planet who has run into this problem. Typical luck for me. Has anyone here run into this? Is the fix to go to a tire shop and tell them that I need the same type of valve stems that the rest of the world has? Talk about a ridiculous problem to have to waste time figuring out. . . Thanks for any / all help.
