Sfisher Subscriber
Sfisher Subscriber
This is a good site for info on the D44. Including what reverse rotation or high pinion actually means.
http://77cj.littlekeylime.com/Dana44.htm
1984 Scrambler
258 / 4.0 head w MPI
"Sfisher" wrote: This is a good site for info on the D44. Including what reverse rotation or high pinion actually means.
Good information in that post!
Paragraph 3 confirms that a HP in front is the stronger set up. I learned about the directional strength over in the Pirate tech section. That's also a great source for other tech information.
Thanks for the link.
Have you guys seen the new d44 rock jocks that currie is making for the tj? There in 4wheelparts new catalog. Are those the same idea of a high pinion in the rear? Are they not going to be as strong as a lp 44 in the rear?
HP D44 is fine for the front, not the rear. For the rear you'll need a LP D44 or a HP D60.
