Battery
  1. Josh Subscriber
    #119 Sep 2016, 5:39 AM
    My Jeep needs a new battery. I'm curious what brand others are using for non daily drivers. What type of battery are you running?
    #219 Sep 2016, 6:20 AM
    I'm running an Optima Yellow top. I've had a while and its still going strong nock on wood
    #319 Sep 2016, 6:45 AM
    Is that the factory battery still Josh?  I might need a new battery soon also.
    #419 Sep 2016, 9:29 AM
    We are running two red-top Optimas and put them in the Jeep not long after we bought it in 2011.  However, we will buy the yellow top once these die.
    #519 Sep 2016, 12:44 PM
    Im in a LJ with the group 34 battery but I did the Sears DieHard Platinum (rebranded Odyssey) when they were available.  I got the M group (marine) to get the extra threaded posts for accessories.  Had a yellow top before that and a red top before that.  All were good AGM batteries, but next go round I will probably just do dual costco generic marine deep cycles.  For the cost, I like the idea of having a backup battery even if its older style lead acid for the same price as 1 name brand AGM.
    #619 Sep 2016, 1:04 PM
    Optima yellow top for me. Free lifetime replacements.
  7. Josh started this Subscriber
    #719 Sep 2016, 2:06 PM
    Gregulator said Is that the factory battery still Josh?  I might need a new battery soon also.
    Greg I currently have a five year old Sears die hard.
    Thanks for all the feedback guys. I appreciate it. Looks like a yellow top is most popular. I'll have to read up on it.
  8. Darrell and Jill Subscriber
    #819 Sep 2016, 11:55 PM
    I am running a Red Top.
    #920 Sep 2016, 12:56 AM
    This might help you:
    https://www.youtube.com/watch?v=FaM7exZmzKY
    #1020 Sep 2016, 2:08 AM
    kris_olof said Im in a LJ with the group 34 battery but I did the Sears DieHard Platinum (rebranded Odyssey) when they were available.  I got the M group (marine) to get the extra threaded posts for accessories.  Had a yellow top before that and a red top before that.  All were good AGM batteries, but next go round I will probably just do dual costco generic marine deep cycles.  For the cost, I like the idea of having a backup battery even if its older style lead acid for the same price as 1 name brand AGM.
    On the TJ/LJ the dual battery set you have to lie them on there side. So unless your using sealed batters they will leak, even so a traditional wet battery wont hold up very long placed on its side.  The lead panels tend to brake off and short out.
    #1120 Sep 2016, 5:32 AM
    That they do.  Would be a custom setup for sure.  LJs have a little more room under the hood as the evap canister is in the rear quarter and not under the hood.  Going to wait until i have tube fenders incase i go with ones that run custom inners but current measurements look good for a custom setup.  Also room in the floor behind the drivers seat as a backup location in the LJ.
  12. Josh started this Subscriber
    #1220 Sep 2016, 7:50 AM
    Thanks Jeff. Very helpful.
  13. Mike G Member Joined: October 2016
    #1320 Sep 2016, 2:33 PM
    I haven't heard anything about a blue top optima battery. This samurai I have been working came with a blue top battery and I'm going to run that in my jeep tj. It's an rv or marine battery so it's good for power and sure starts after sitting awhile. Any opinions on that one?
    #1420 Sep 2016, 3:24 PM
    Mike G said I haven't heard anything about a blue top optima battery. This samurai I have been working came with a blue top battery and I'm going to run that in my jeep tj. It's an rv or marine battery so it's good for power and sure starts after sitting awhile. Any opinions on that one?
    I had a blue top.  It didn't last very long for me.  The value was for a refrigerator in my case, where it was an extra battery.
    #1521 Sep 2016, 3:30 PM
    I'm running an Odyssey. So far so good. They didn't have the Sears Platinum for the 2012 and up. Poles are reversed.
  16. Josh started this Subscriber
    #1622 Sep 2016, 2:34 AM
    k-jeep said I'm running an Odyssey.  Poles are reversed.
    Kevin
    Why do you like this "Poles are reversed"?
  17. kris_olof Trailmaster Joined: October 2015
    #1722 Sep 2016, 2:59 AM
    Josh said
    Kevin
    2012 and up JK uses a different battery, Group 91 maybe? It is basically the same as the Group 34 of TJs and 07-11 JKs but with the poles reversed.  My guess is that this was the work of the same engineer that suggested the use of Torx hardware.
