Dana 30: removing/repositioning inner Cs
  1. Tom Subscriber
    #121 Jan 2014, 12:15 AM
    I can see where the C is welded to the axle tube.
    With the lift being run, approximately 6-1/2", would it be a good idea to adjust the Cs to bring the caster back into spec and realigning the front driveshaft? Or it is too much hassle for too little return?
    #221 Jan 2014, 6:25 AM
    That's a great question. I wouldn't do it without an axle jig. Or have it professionally done.
    #321 Jan 2014, 9:12 AM
    What about adjustable control arms?
  4. Tom started this Subscriber
    #421 Jan 2014, 11:35 AM
    I have adjustable upper and lower control arms so that part is good. I can get camber where it needs to be.
    Looking to improve the pinion angle with the correct camber.
    #521 Jan 2014, 11:39 AM
    What are other XJer's doing? Honestly, I wouldn't do it. You're investing a lot of money and time into what some people consider a throw-away axle. Just my thought. If you aren't having issues with it on the road then you are trying to fix something that isn't broke.
    Do you have issues with the pinion angle? Possibly drive shaft issues? I would get a cv style driveshaft before messing with cutting and welding.
    #621 Jan 2014, 1:25 PM
    A cv driveline solves the problem. Why throw away money time and effort trying to remod a d30? Doesn't seem logical. I did upgrades to my 30, including an ARB. I got 150 for it when i sold it. It's not worth anything. The driveline can be reused on whatever axle you buy in the future...
    #721 Jan 2014, 9:34 PM
    Ah, I understand now. I read "caster angle" and thought you were having alignment issues (my bad). I agree with the others, the driveline is the easy fix.
    #89 Feb 2014, 6:26 AM
    Tom your talking about what they call a "cut an turn". Search it, you'll find info on it. This is something you would want a shop to do.
    You now you should never bring up a ? about 30's on this forum, right?
  9. Tom started this Subscriber
    #910 Feb 2014, 5:30 AM
    It gets me around. BTW, don't you have a D30 on your rig?
    #1011 Feb 2014, 11:58 AM
    Ssh, keep it down. The last time I talked about my 30 I got ganged up on by 60′s guys. Their ruff I tell ya.
    I did a lot of searches on what one could do with a 30…. And yes if I want to keep up with you Dana 60 guys I’m going to have to step-it-up.
  11. Tom started this Subscriber
    #1111 Feb 2014, 9:45 PM
    My rig doesn’t have a “frame” either so I get it from that crowd as well. 💥
  12. Josh Subscriber
    #1211 Feb 2014, 11:51 PM
    All questions should be ok. Its about helping the other guy out. Take the good that you learn and throw away the bad.
    #1312 Feb 2014, 6:08 AM
    Just out-wheel the guys with the 60s, works for me :)
  14. Tom started this Subscriber
    #1412 Feb 2014, 4:15 PM
    Awwwww, it's all good natured ribbin'.
