Kevin,
Found a HP D70, full float for about 5K, but you need an ARB, RnP and install kit. it has 5x5.5 bolt pattern and is 66" wide. I'm guessing its about 6500 total. Includes tone rings and bolts in to a JK...
Dana 70 Kevin?
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009Hmm, let me think about that one. My original plan was to do the front first to replace the D30.
Do you know what it came out of originally?
Thanks for the heads up.
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012Kevin needs some 9 inch axles. What do you think of these Kevin?
http://www.trail-gear.com/rock-assault-nine-roller-kitsUm...what?
BKGM Jeepers President Joined: June 2003BKGM Jeepers started this President Joined: June 2003"k-jeep" wrote: Hmm, let me think about that one. My original plan was to do the front first to replace the D30.
New. Custom built. Not a junkyard axle.Kathleen and Brad
BKGM Jeepers President Joined: June 2003BKGM Jeepers started this President Joined: June 2003"finder_87" wrote: Kevin needs some 9 inch axles. What do you think of these Kevin?
I don't see tone rings allowing it to run correctly in a JK. We're they optional? Or are they available?Kathleen and Brad
huck271 Subscriberhuck271 SubscriberIf you are going to spend that much you should get a rockjock70. Its a bolt in.
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012"BKGM Jeepers" wrote: [quote="finder_87"]Kevin needs some 9 inch axles. What do you think of these Kevin?
I don't see tone rings allowing it to run correctly in a JK. We're they optional? Or are they available?What's a tone ring. :rasta:
huck271 Subscriberhuck271 SubscriberThe JK has an ABS system that checks wheel spin by counting teeth on a tone ring. No ring, no signal, ABS goes crazy and your dash looks like a christmas tree.
BKGM Jeepers President Joined: June 2003BKGM Jeepers started this President Joined: June 2003"huck271" wrote: The JK has an ABS system that checks wheel spin by counting teeth on a tone ring. No ring, no signal, ABS goes crazy and your dash looks like a christmas tree.
Greg was joking. Well, im pretty sure he was!Kathleen and Brad
BKGM Jeepers President Joined: June 2003BKGM Jeepers started this President Joined: June 2003The axle i posted is a rock jock 70.. Yes it is bolt in..
"BKGM Jeepers" wrote: [quote="huck271"]The JK has an ABS system that checks wheel spin by counting teeth on a tone ring. No ring, no signal, ABS goes crazy and your dash looks like a christmas tree.
I think he was asking so I would know. He's good that way. π
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012"Bender" wrote: [quote="BKGM Jeepers"][quote="huck271"]The JK has an ABS system that checks wheel spin by counting teeth on a tone ring. No ring, no signal, ABS goes crazy and your dash looks like a christmas tree.
I think he was asking so I would know. He's good that way. πHaha!!
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012Kevin!!! Watch this!!!
http://www.powerblocktv.com/episodes/XT ... eep-part-1
They had Ruff Stuff 9 inch JK axles on this weeks episode of Extreme 4x4. They are running a hemi with 44 PBRs. I think that proves there strength. Check it out!!Um...what?
BKGM Jeepers President Joined: June 2003BKGM Jeepers started this President Joined: June 2003Can you get 5.13s in the 9?
Jeff- that guy with the foolsize SubscriberJeff- that guy with the foolsize SubscriberYou can go 5:13 or 5:43s in 9" center
BKGM Jeepers President Joined: June 2003BKGM Jeepers started this President Joined: June 2003"Path 88" wrote: You can go 5:13 or 5:43s in 9" center
Thanks Jeff!
My front is 5.13 so I'd need to match it...Kathleen and Brad
Jeff- that guy with the foolsize SubscriberJeff- that guy with the foolsize SubscriberI would never run a high pinion rear. It will break on you. Just ask Huck.
BKGM Jeepers President Joined: June 2003BKGM Jeepers started this President Joined: June 2003I have a rear HP60 and have never had any problems with it. However I don't run 375 hp/400 ft/lbs torque.
I am looking to be proactive in knocking out upgrades before the motor swap. The rear axle is my last item unless I need to do an auto conversion as well. But I want something that solves the problem, and not something that was the cheapest solution. I've already got an axle back there, so "do nothing" is a solution as well.Kathleen and Brad
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012Brad, do you know what motor your going to put in? Diesel!?!? Or hemi?
BKGM Jeepers President Joined: June 2003BKGM Jeepers started this President Joined: June 2003"finder_87" wrote: Brad, do you know what motor your going to put in? Diesel!?!? Or hemi?
Either a 2012 or a 2013 hemi. no diesel for me...Kathleen and Brad
