Just bout a pair of baofeng uv 5r mk5 radios. What frequency is the club using on trail rides ?
Frequency setting
infotraker Member Joined: February 2020infotraker Member Joined: February 2020Jim Ruppel
kris_olof Trailmaster Joined: October 2015kris_olof Trailmaster Joined: October 2015The club has an FCC license for some business frequencies that cover this area of california and parts of nevada. The frequencies are:
151.700 MHz
151.760 MHz
154.5275 MHz
469.500 MHz
469.550 MHzThe leader of whatever run you are on will pick the frequency, usually one of these or one of the GMRS/FRS frequencies if some people only have little motorola type walkie-talkies. There is sometimes interference in urban areas as fast food drivethrough headsets are low power and can be licensed on the same or close frequencies. Send a message to Tyler (club name "Tyler - K6TLR"😉 and he can set you up with the legal programming file for the radio if you aren't already HAM licensed.
