Hey Greg / Kevin
    #111 Aug 2017, 1:03 AM
    Kevin, can you set up an "Ask Greg" forum for me [joke]   🤡
    Greg, if you get a chance, could you measure the length of your front lower control arm (center of bolt to center of bolt)?
    Thanks
    #211 Aug 2017, 4:57 AM
    23 1/16"
    These are the measurements that I used in the instructions from the metalcloak kit: http://www.armoredworks.com/metalcloak/instructions/SUSPENSION/II-7110-35-GAME-CHANGER-JK.pdf
    #311 Aug 2017, 6:41 AM
    Thanks Greg. The adjustable Synergy arms says 23-1/4". I am currently at 22-7/8". That's only about 1/2" difference though, not sure if that's going to be enough to stop rubbing? I'm getting tired of having to do all these three point turns in parking lots!!!
    #413 Aug 2017, 3:05 AM
    I threw the full doors back on today. Just that "slight" bit of droop to the suspension turned the hard rub into a slight rub. Looks like extending my front axle just 1/2" will make all the difference.
    #515 Aug 2017, 12:49 AM
    I'd like to push mine forward even more than what it currently is.  I had the chance to drive Jeff's jeep and realized his doesn't turn as sharp as ours can.  His steering stops are what's limiting his rubbing issue.  Plus it's a 5.5" lift...
    #615 Aug 2017, 12:59 AM
    Gregulator said I'd like to push mine forward even more than what it currently is.  I had the chance to drive Jeff's jeep and realized his doesn't turn as sharp as ours can.  His steering stops are what's limiting his rubbing issue.  Plus it's a 5.5" lift...
    Good info. Thanks.
    We will get these tuned 🙂
    Let me know of any updates, my adjustable lowers are 3 weeks out.
