It's a Jeep thing
    #269 Jan 2016, 12:18 AM
    Brad, Could you do the spyntec conversion on it? Or contact dynatrac and see if they have a spindle hub conversion? I've also heard that dodge unit bearings are plug and play with JKs.
    If you wanted to keep your housing for simplicity, you could always swap from the knuckles out to ultimate dana gear or dynatrac or ruffstuff or anyone else. Maybe this could be the easiest way but may cost more. But at this point I think fixing the issue is bigger then saving a few pennies.
    Nothing is worse than having some small problem cripple your rig and spirit for the great outdoors. Keep your head up and let me know if you need help. I will gladly call manufactures and help find a solution!
    #279 Jan 2016, 3:45 AM
    I appreciate the ideas and am open to anything!
    I talked to spin tech. I have Ford unit bearings with Dodge tone rings attached. They don't make a solution so it would be custom.
    I wonder what Kevin's axle has and if I could use that...
    #289 Jan 2016, 10:45 AM
    If my outers go missing I know where I'm looking first! 😀
    Here's more info...
    http://spicerparts.com/products/axle/automotive/ultimate-60
    #299 Jan 2016, 11:05 AM
    If my outers go missing I know where I'm looking first! [https://posse4x4.org/wp-content/sp-resources/forum-smileys/biggrin.png]
    Here's more info...
    Thanks. It looks like the front end is high pinion too.
    #309 Jan 2016, 11:08 AM
    Yes, HP front, LP rear.
    #319 Jan 2016, 11:12 AM
    So I'd need to switch to 5.38s. Switch to 8 lug. Switch to accept coil overs.
    Is hi steer standard?
    #329 Jan 2016, 11:35 AM
    Yes, yes, yes, and yes.
    Everything listed is standard. Not sure if you can just buy outers. Might be worth a call. That might be the best option if they can do outers.
    #339 Jan 2016, 11:45 AM
    I wouldn't be scared away from custom machined hubs if everything else in the kit is standard. As long as locking hubs are the weak link and you keep the bearings greased, the hub seems like a forever part to me.
    Also sounds like the Spyntec ordered with blank or custom machined hub/tone ring still might be the easiest in terms of not having to regear or redo steering.
    #349 Jan 2016, 12:25 PM
    Or if you think the issue is curries source for unit bearings: http://www.branikmotorsports.com/dana60.htm
    Actually thinking about the frequency of unit bearing issues, have you had alignment? All bearings been on one side? Positive camber would point me to manufacturing defect, negative to a bent C.
  10. scoped Subscriber
    #3510 Jan 2016, 12:19 AM
    Ya your positive camber has always concerned me. Positive camber is never a sought after thing and normally points to bad, bent, or broken
    #3610 Jan 2016, 1:50 AM
    I get my jeep alligned every 1000 miles ish. Every spring and every fall. I haven't done my fall alignment however because of this problem. Cost of my tires supports them!
  12. BKGM Jeepers started this President Joined: June 2003
    #3718 Jan 2016, 8:23 AM
    Replacing a unit bearing takes 90 minutes.
    BUT when you have the steering tone sensor replaced you better have all your keys present so they get recoded!
    Otherwise, your jeep runs and then cuts out. Then goes dead!
    #3818 Jan 2016, 1:26 PM
    That doesn't sound fun. Lol
  14. scoped Subscriber
    #3918 Jan 2016, 3:37 PM
    Yay for electronics
    #4019 Jan 2016, 1:46 AM
    Were you able to get them re-coded?
    How do the tone rings affect the keys? Just wondering because I swapped out my axles without issue. Or will my spare key not work now? I'll have to try it.
    #4119 Jan 2016, 2:07 AM
    The tone ring I struggled with was in my steering column. Not on the axles.
    Now it looks like one of my sensors is bad. Ill need to order it and swap it out m however it requires me to take off my rotors.
    At least I can drive the jeep again. And my LED lights are awesome! 10x the light over srock. I was worried about blinding oncoming cars so I conservatively posted them lower. They are awesome when you pull behind a Prius, or Mini Cooper at a stoplight. It lights up the inside of their car like daylight!
  17. davesjk Subscriber
    #4219 Jan 2016, 12:41 PM
    At least I can drive the jeep again. And me LED lights are awesome! 10x the light over srock. I was worried about blinding oncoming cars so I conservatively posted them lower. They are awesome when you pull behind a Prius, or Mini Cooper at a stoplight. It lights up the inside of their car like daylight!
    what brand of lights did you go with? I was looking at truckle
    #4319 Jan 2016, 12:47 PM
    I don't know. Mine were 200 bucks total and I bet they are brighter than both the truck lights and the JB speaker brands.
  19. davesjk Subscriber
    #4419 Jan 2016, 12:55 PM
    well the truck lites are 400. i would love to save 200 if your happy with the ones you got
    #4519 Jan 2016, 1:42 PM
    How do you not know what brand they are Brad? You're killing me!! I need new headlights ASAP!!! I don't want to spend $400. I see that procomp is coming out with a set of LED headlights but they are only available for Pre order with a delivery in April. Looks like price will be around $275.
  21. BKGM Jeepers started this President Joined: June 2003
    #4619 Jan 2016, 9:40 PM
    They were a Christmas gift off eBay I believe. Just search over there. If I could post a pic it would make them easy to identify. They are CREE LEDs, supposedly.
    #4720 Jan 2016, 1:14 PM
    7 Inch Round LED Headlight [Pair] Jeep 97-15 Wrangler JK LJ TJ CREE LEDS
    Use this as a search on eBay. They are 45w lamps.
  23. davesjk Subscriber
    #4822 Jan 2016, 10:21 AM
    awesome, thanks Brad!
