My Jeep is road worthy again after sitting dead for over 7 months 😲
Thanks to Rob for all his help. He worked his butt off, awesome guy to have as a friend!
To start with, the Jeep wouldn't start. I had to jump start the battery. When it finally started, the engine compartment started smoking a lot. The oil seperator leaked out all of its oil when the air pressure hit it, but it soon burned off. Then I couldn't get it in gear. It seems that leaving it parked for that long rusted the clutch plates together. Once running, we took it to Rob's house. We fixed the whole front end of the Jeep:
Re-weld the broken shock mount
Took the axles out and cleaned-regreased everything
New seals and slinger plates on the hubs
Brand new hubs
Shortened drag link and recentred
Re-attached the steering stabilizer
Re-routed the air line to bypass the oil sperator
New brake line
Bled the brakes
Oh ya, and repainted some stuff 😈
So the front end is done and I can drive it again. We now need to finish the back end to get it trail worthy. We will need to replace the rear shocks and do some maintenance on the rear/lower control arms. After that, I should be good to go...
Jeep update
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003I used to wheel a lot. . .
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009🍺
Sounds like a busy weekend!
Fred SubscriberFred Subscriber"JohnDF" wrote: after sitting dead for over 7 months 😲
:slap:
Glad to hear you've made some progress on it
Justin SubscriberJustin SubscriberNice John!!!
Is Rob almost done so he can help me with my Jeep? 😀- RobD SubscriberRobD Subscriber
John and his new outboarded shocks. How does it feel to be able to change a shock in a couple minutes unlike the two plus hours it took us to get your old ones out of the stock mounts 😲
Uploaded with ImageShack.us
Uploaded with ImageShack.us__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan - RobD SubscriberRobD Subscriber
You really need to put a coat of paint on the underside of your Jeep 😁
