dont know if u guys do your own work or not but
theres a lifted xj at pick n pull
so far its complete
adjustable track bar
upgraded front end
its all there as of today
drivelines
im going to try and grab trak bar
if anyones interested
lifted XJ
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009If it still has the axles and they're the same as yours pull the shafts if you can for spares. 😁
Tom SubscriberTom Subscriber"Rayzor" wrote: dont know if u guys do your own work or not but
so far its complete
upgraded front end
drivelines
If you are asking is I'm interested in an adjustable track bar, then the answer is yes. See if you can get the mount that goes against the body as well if is is dropped.
Is the pitman arm dropped as well? If it is, take it and I'll make it right to you.
im not going to make it back there til sunday (a day off)
if you go its white 4 door
has a #23 on side of front fender
im thinkin thats the stock number
the steering rods are upgraded from stock ones
Tom SubscriberTom SubscriberYeah, I'm in the same boat as you with no real time off until at least Saturday ... and last Saturday I was called in because things are VERY busy at present.
