Posse Radio Programming Information
    #110 Jun 2025, 4:16 AM
    Hi Everyone! I am going to try to remember to start bringing my computer to meetings so that I can program Baofeng radios during meetings with the latest updates, and provide a printout reference to go along with it. If I previously programmed your radio's and want me to upload the latest information and settings tweaks, maybe remind me in the meeting post until I get in to the habit!
    If you are interested in programming your own radio's with CHIRP, I will post all the latest files to upload the channels I put on radio's when I program them as well as some other information that might be helpful if creating you own upload files. Hit me up at a meeting or post up here if you have any questions!
    "Posse Core Prog File 6-10-25.txt": This is the file to upload all the channel information in to a Boafeng radio. Note that you must change the file extension from .txt to .csv before uploading!
    "Posse Print File 6-10-25.pdf": This is a file you can print that is a companion reference for the latest upload file.
    "CHIRP Template Definitions.png": This is an image to reference all possible columns of a CHIRP upload file. Use this to create custom upload files for yourself including other radio manufacturers supported by CHIRP. To get a blank template from CHIRP to start with, click "File > New" then export that new programming file to a CSV by clicking "File > Export to CSV".
    Posse-Print-File-6-10-25.pdf
    Posse-Core-Prog-File-6-10-25.txt
    #210 Jun 2025, 12:56 PM
    Thanks Jamie!
  3. Dale Clement Member Joined: June 2015
    #311 Jun 2025, 1:37 AM
    😀I’m glad you understand all of that, I just turned it on and hoped it works.
  4. Nubby started this Webmaster K6NUB Joined: February 2018
    #411 Jun 2025, 11:49 PM
    Pay no attention to the man behind the curtain.....
    Dale Clement said 😀I’m glad you understand all of that, I just turned it on and hoped it works.
  5. Calaveras32Spcl Member Joined: May 2023
    #512 Jun 2025, 1:53 AM
    I think I need to look into CHIRP so I can work on my AnyTone that I installed in my vehicle. I can receive on it, but can't seem to broadcast on it.
    Dale Mogg - WRZG209
