Rock Jock 70 FF
    #120 Aug 2014, 5:39 AM
    What's everyone's thoughts on the new Currie Rock Jock 70 full floater rear axle? Do you think it will be stronger then the 60 full float? Obviously it will have larger gears, but what about it being a high pinion application?
    http://www.currieenterprises.com/cestore/Products4x4.aspx?id=4468&p=5299.9500
    Second question for those with the Rock Jock 60 rear semi float, has anyone had issues besides Huck's ring and pinions? Anybody bend some axle flanges? I hear that is a common occurrence.
  2. Josh Subscriber
    #220 Aug 2014, 11:14 AM
    Gregulator said Second question for those with the Rock Jock 60 rear semi float, has anyone had issues besides Huck's ring and pinions? Anybody bend some axle flanges? I hear that is a common occurrence.
    I have a Currier 60. I like it. I've busted the rock skid. Easy fix. I also tore of the upper rear link mounts. I had it welded up and added some gussets for strength. The tabs could be stronger. Would I buy it again? Yes.
    There will always be something better and stronger.
    #320 Aug 2014, 11:34 AM
    No problems from my RJ 60, but i dont run a hemi, or a real motor![https://posse4x4.org/wp-content/sp-resources/forum-smileys/icon_drool.gif]
    I consider myself to be harder than average on my jeep as well. It's probably the lack of HP n torque saving me.
    #420 Aug 2014, 1:10 PM
    How and when did you tear the upper links? You animal!!
    #520 Aug 2014, 1:11 PM
    Are you guys running the set 80 bearings?
    #620 Aug 2014, 1:12 PM
    I'm pretty sure we both are.
  7. Josh Subscriber
    #721 Aug 2014, 2:37 PM
    May 2014 - Hell Hole trail.
