Fred Subscriber
Fred Subscriber
Does anyone know if the TJ Rubicon rear Dana 44 axle requires the friction modifier in the gear lube? I know they've got the limit slip / locker but my FSM doesn't cover Rubicon models.
Thanks
Thanks
It doesn't tale the modifier because there are no clutches.
😎 Thanks
"JohnDF" wrote: It doesn't tale the modifier because there are no clutches.
Is this because the TJ Rubicon has a Locker and not an LSD? I recall the TJ LSD required the additive...
"BKGM Jeepers" wrote: [quote="JohnDF"]It doesn't tale the modifier because there are no clutches.
TJ Rubicons have a locker/limited slip. The regular TJ limited slip does have clutches and requires the friction modifier.
