My ignition kill switch module is finally going out after about 16 years of use. It was a phone style keypad in the cabin and you had to punch in a code to start the vehicle. I've seen other cheap ones but haven't been able to find the same one.
This is for a 92 YJ. I don't want a "hidden" manual switch under the dash that anyone can find if they look hard enough.
(I know, if they want it bad enough they will find a way to bypass any system.)
I like the idea of the MasterLock Starter Sentry but they only go back to 1996 in their vehicle lookup.
Does anyone have any recommendations?
Starter/Ignition Kill Switch
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003"kevheb" wrote:
Beat up your Jeep as bad as mine is...nobody will want to steal it...and it's free πI used to wheel a lot. . .- Guest former userGuest former user
"JohnDF" wrote: [quote="kevheb"]
There are some desperate people out there! Some people will even steal a Toyota!! π² - Anonymous former userAnonymous former user
change the code to use new numbers?
k-jeep Member Joined: May 2009k-jeep started this Member Joined: May 2009HOLD EVERYTHING!!!
false alarm.
I found the loose wire. :rasta:
Let's see if I can get 16 more years out of the keypad kill switch. π²
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003You should still dent the cr@p out of it just to be on the safe side.
