You need a blue wrench. π
Stuff I'm doing
Justin SubscriberJustin Subscriber
Dan-H SubscriberDan-H SubscriberPB blaster, and hit it with a torch, then ice it then hit the side with a hammer then try to unthread it.
but watch out as the PB blaster might be flammible.Closed Mondays.
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003"Justin" wrote: You need a blue wrench. π
and a vice. Heck, I'd be happy to just find a flashlight that works around here. Been that kind of day...
Howdy SubscriberHowdy SubscriberSounds like my kind of day though I did get my bump stops welded on and a couple u-bolts replaced, but it was a battle the whole time. I even ended up breaking my vice. My son wanted us to get the tires back on and go for a spin, but by that time I had had enough frustration so we called it a day and came in and had lunch.
Fred SubscriberFred Subscriber"JohnDF" wrote: [quote="FAM"][quote="JohnDF"]I can get the TREs off the knuckles. The TRE on the drag link is the problem. I can't get it out of the end of the drag link. I think somebody welded it in there as a joke.
Did you try a pickle fork and a BFH?It's threaded, how's a pickle fork going to help?
I've never seen a TRE threaded into the pitman arm. You'll see threads where you removed the castle nut, but those threads don't go all the way through the pitman arm. Where the TRE goes through the pitman arm it should have a smooth tapered fit.
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003π We have a failure to comunicate (movie?) π
The TRE is threaded into the drag link, not the pitman arm.I used to wheel a lot. . .
Fred SubscriberFred Subscriber"JohnDF" wrote: The TRE is threaded into the drag link, not the pitman arm.
π³ Where the heck did I get "pitman arm" from? π³
Anyone have a copy of Rosetta Stone I could borrow to relearn English?- Guest former userGuest former user
"JohnDF" wrote: π We have a failure to comunicate (movie?) π
The TRE is threaded into the drag link, not the pitman arm.guns and roses, what we have here is a failure to communicate. its in a song.
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003It was in a movie first...in fact the sound clip from the movie...might be before your time Alex π
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"JohnDF" wrote: It was in a movie first...in fact the sound clip from the movie...might be before your time Alex π
I've heard it from two actors - Gene Hackman and Morgan Freeman.
Who is the actor you are referencing?Kathleen and Brad
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003I used to wheel a lot. . .- Guest former userGuest former user
"JohnDF" wrote: [quote="BKGM Jeepers"]
The original...this guy...from Cool Hand Luke π Finally tripped up the master π
"sometimes nothing is a pretty cool hand"
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003I guess I'm just not old enough. π
Dan-H SubscriberDan-H Subscriber"JohnDF" wrote: [quote="BKGM Jeepers"]
shakin the bush bossClosed Mondays.
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003"Dan-H" wrote: [quote="JohnDF"][quote="BKGM Jeepers"]
shakin the bush bossI forgot that one π We need to use that on our runs.I used to wheel a lot. . .- RobD SubscriberRobD Subscriber
I will be home Sat. afternoon if you want to work on your Jeep.
Dan-H Subscriber
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003I have no torch.
Dan-H SubscriberDan-H Subscriber12.97 @ lowes
http://www.lowes.com/lowes/lkn?action=p ... lpage=noneClosed Mondays.- Guest former userGuest former user
"JohnDF" wrote: I have no torch.
Lighter? π
I have a little propane torch you can borrow, but for what it would cost in gas to get it to you, you could probably buy one.
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003I'll get it figured out. I need a torch and a vice. Might be time to visit Sears.
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003Doesn't the torch attach to propane bottle (like for camping)?
Dan-H SubscriberDan-H Subscriberyes. the link I pasted includes a bottle.
The tall skinny ones are easier to hold.Closed Mondays.
Dan-H SubscriberDan-H Subscriberyou can also use the torch to make CrΓΒ¨me brΓΒ»lΓΒ©e
Closed Mondays.- RobD SubscriberRobD Subscriber
"JohnDF" wrote: I can get the TREs off the knuckles. The TRE on the drag link is the problem. I can't get it out of the end of the drag link. I think somebody welded it in there as a joke.
Just bring it to my house and you can use my vise, torch, and anti seize for the threads when you put it back together..__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan
