The lowering and stretch
  1. RobD started this Subscriber
    #5110 Feb 2008, 7:13 AM
    "FAM" wrote: Is there much metal left for the fronts of the rear flares to bolt up to?
    There was plenty. It is only temporary until after the Hammers and then I will put tube fenders back there.
  2. RobD started this Subscriber
    #5211 Feb 2008, 7:16 PM
    The stretch is going good, I was over there today. All the old brackets are cut off and he is moving the spring buckets back tmorrow and building the new arms. We measured the wheel base where axle will sit when done and I am just over 101 inches πŸ˜€
    My new roll cage comes in tomorrow, so John and I will be installing it this weekend, changing out my front axle U-joints, putting all new tie rod and drag link ends on, installing my stage 8 kit, etc....
  3. Fred Subscriber
    #5311 Feb 2008, 7:20 PM
    Which roll cage did you end up getting?
    #5411 Feb 2008, 8:59 PM
    I'll be there to help. We can also change the joints in my rear/uppers.
  5. RobD started this Subscriber
    #5512 Feb 2008, 7:34 AM
    "FAM" wrote: Which roll cage did you end up getting?
    I went with the Rock Hard cage after talking with several shops who all said it's as good as a weld in cage if not better....It isn't a cheap either 😲
  6. RobD started this Subscriber
    #5614 Feb 2008, 10:23 PM
    My Jeep is done. I will pick it up Sat. when I get back into town. He decided not to notch the frame. He moved the buckets back and it only raised the rear an inch. I have to drive it home in front wheel drive. Apparently my drive shaft doesn't connect anymore. The front half and the rear half of the shaft are about 4 inches from connecting.
    #5715 Feb 2008, 7:10 AM
    I'll be waiting for pictures!
    #5815 Feb 2008, 7:18 AM
    I know where Justin lives...we can get you a new drive line in about five minutes...bring your tools...
  9. Justin Subscriber
    #5915 Feb 2008, 8:07 AM
    "JohnDF" wrote: I know where Justin lives...we can get you a new drive line in about five minutes...bring your tools...
    #6016 Feb 2008, 7:42 AM
    Today is the day 😎
    #6116 Feb 2008, 8:42 AM
    "JohnDF" wrote: Today is the day 😎
    Tick tick tick...still waiting for pictures! πŸ˜€
  12. RobD started this Subscriber
    #6216 Feb 2008, 8:46 AM
    "Bender" wrote: [quote="JohnDF"]Today is the day 😎
    Just got back in town from Tahoe. I will pick it up tonight when I get out of bed..I will try and get some photos if it isn't to dark..
  13. Justin Subscriber
    #6316 Feb 2008, 9:59 AM
    Can I come over and play tommorrow? πŸ˜€
  14. RobD started this Subscriber
    #6416 Feb 2008, 4:29 PM
    "Justin" wrote: Can I come over and play tommorrow? πŸ˜€
    I am planning on about 9:00 a.m. and we can get breakfast first if anyone is up to it...
  15. RobD started this Subscriber
    #6516 Feb 2008, 7:05 PM
    Breakfast in Loomis at 8 a.m. same place as last week..
    #6616 Feb 2008, 7:42 PM
    We'll be there
  17. Justin Subscriber
    #6717 Feb 2008, 6:02 PM
    Your Jeep looks good Rob. I really liked how the rear buckets turned out.
    Thank you John and Rob for helping me beat and drill on my Jeep today. I have to pull the soft top back one more time for the spreader bars and might need some help getting it back on. πŸ˜‚
    #6817 Feb 2008, 6:25 PM
    Wheel base is over rated πŸ˜€
  19. RobD started this Subscriber
    #6917 Feb 2008, 6:28 PM
    Here are the photos of the work.
    This is how the buckets were moved back.
    The red line shows where the back of the tire used to be.
  20. Fred Subscriber
    #7017 Feb 2008, 6:38 PM
    Looks good!
  21. Justin Subscriber
    #7117 Feb 2008, 6:39 PM
    "JohnDF" wrote: Wheel base is over rated πŸ˜€
    We will see! 😏
    #7217 Feb 2008, 6:42 PM
    That looks really good! Much better than the notch, I couldn't stand that notch on mine when I had it. Do you have any more pics of your rear shock mount from different angles? It looks a couple pieces of 1" or so 1/4" plate and a tube welded in the middle as a mounting sleeve, is that what it is? Nice welds too!
    #7317 Feb 2008, 7:14 PM
    Very nice. What did the final wheelbase end up at?
  24. RobD started this Subscriber
    #7417 Feb 2008, 7:15 PM
    "troyman" wrote: That looks really good! Much better than the notch, I couldn't stand that notch on mine when I had it. Do you have any more pics of your rear shock mount from different angles? It looks a couple pieces of 1" or so 1/4" plate and a tube welded in the middle as a mounting sleeve, is that what it is? Nice welds too!
    Very simple shock mount, Brad had his done after I got mine. A guy I know up in Foresthill made them. Here is a link with some more photos..
    https://posse4x4.org/forum/viewtopic.php ... rd&start=0
  25. RobD started this Subscriber
    #751 Mar 2008, 3:17 PM
    Here are the flex pictures. I wanted to make sure everything worked before the Hammers. This is with the Jeep all bump stopped correctly.
    Almost full flex.
    Full stuff in the rear with 4 1/2 inch springs. Plenty of room
    Full flex in the rear..Plenty of flex I would say!!!
