The lowering and stretch
January 22, 2008
1:30 am
John and I got my Jeep all set up today. We got the pinion angle set and we stretched the wheel base close to 3 to 4 inches, my wheel base is now 97 inches. I am still going back another 2 inches in the rear and the front will go forward another 1 inch, so I can get to 100 inches. Tomorrow I am doing a modified comp cut on my jeep to accommodate the current wheel base. Photos to follow....
January 22, 2008
1:31 am
"RobD" wrote: Photos to follow....
Glad you said that so I didn't have to post this:
:worthless:
lol Keep stretching and soon you'll be as cool as a Toyota.
January 22, 2008
3:44 am
Now you need a set of these...
[Image Can Not Be Found]
3:45 am
Justin
Forum Posts: 1416
"Bender" wrote: Keep stretching and soon you'll be as cool as a Toyota.
You mean as cool as a Jeep Unlimited. 😈
January 22, 2008
3:42 pm
You're out there cutting it right now aren't you?
3:50 pm
Forum Posts: 7065
"Justin" wrote: [quote="Bender"] Keep stretching and soon you'll be as cool as a Toyota.
What's the difference in wheelbase between Rob now, and your unlimited Justin?
January 22, 2008
3:55 pm
"JohnDF" wrote: You're out there cutting it right now aren't you?
:worthless:
4:00 pm
Justin
Forum Posts: 1416
I am at 105" right now. I think with a little arm adjusting, I could get 107".
January 22, 2008
4:07 pm
Forum Posts: 7065
Rob, how do you get the control arms that long? Did you lengthen them, or move the brackets back?
January 22, 2008
4:13 pm
"Justin" wrote: [quote="BKGM Jeepers"]
Shorty. lol
Real men run at 110"! 😀
January 22, 2008
5:08 pm
"BKGM Jeepers" wrote: Rob, how do you get the control arms that long? Did you lengthen them, or move the brackets back?
I purchased new RE control arm couplers that are an inch longer and then lengthened my arms two inches, plus I got about an inch or two when I lowered my Jeep. My rear arms are almost parallel to the frame now. I still need to move the upper spring buckets back a few inches. When I move them back, I am going far enough to lengthen my arms another inch or two. There is still enough room on the threads to do it.
Next week I am lowering the front another inch and ordering comp cut crusher corners from Gen Right to accommodate the stretched wheel base.
Now all I need are shorter shocks, but I may do coilovers in the rear instead spending $250 on a good set of rear shocks.
January 22, 2008
5:33 pm
Forum Posts: 7065
"RobD" wrote: [quote="BKGM Jeepers"]Rob, how do you get the control arms that long? Did you lengthen them, or move the brackets back?
Great Job! That's a ton of work! I was going to ask what you are doing to clear the front. That gen right kit should move the fenders up several inches. Are your front PS tube fenders for sale?
January 24, 2008
6:42 am
should have just gotten a cherokee or a unlimited
January 26, 2008
1:24 am
Taking the Jeep in this week to get the rear upper spring buckets moved back on the frame so my springs will be vertical.
January 26, 2008
4:21 am
TJs rule the world 😈
5:16 am
"JohnDF" wrote: TJs rule the world 😈
After you bolt $50,000 worth of extra parts onto them. 🙄
January 26, 2008
5:46 pm
Who's welding on the coil buckets?
If you weld them in so the coil is straight up and down, you'll be the same height as before.
9:23 pm
"JohnDF" wrote: Who's welding on the coil buckets?
I have a guy up here in Auburn that fabs out of his garage. I will gain about an inch from moving them back, but that is temporary. I am going to run coil overs back there.
January 26, 2008
10:10 pm
You made of $$$$ ????
7:18 pm
Going down to buy a cut off wheel and start hacking at my Jeep 😯
January 27, 2008
8:44 pm
Bummer. I wanted to be there but I'm sick. Take pictures.
12:30 am
Before
January 28, 2008
12:31 am
After the cutting 😀
January 28, 2008
12:32 am
Flare put back on but moved back 2 inches
January 28, 2008
12:33 am
The stuff I cut off
