Toyota lift kit
JohnDF Member Joined: July 2003JohnDF Member Joined: July 2003I used to wheel a lot. . .- Guest former userGuest former user
Cool. I've got some 3" blocks laying around. Why not throw those in there too. 😎
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003ooohhh...ya...stacking blocks would be cool 😂
This kit has 1-1/4" blocks for the rear and 3" spacers for the front.
Now I'll need to hit up Lee for those 33" tires (after I talk the "boss" into it) 😎I used to wheel a lot. . .- RobD SubscriberRobD Subscriber
Who makes the lift kit?
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003Tuff Country...but it's just a spacer lift...what could go wrong 😂
"JohnDF" wrote: ooohhh...ya...stacking blocks would be cool 😂
Keep on stacking! 😎
"JohnDF" wrote: Tuff Country...but it's just a spacer lift...what could go wrong 😂
You sure you want to ask that?
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003Let me restate that...it's a 1-1/4" aluminum spacer...what could go wrong.
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003Boy oh boy...I thought you guys would be excited to see a Toyota build thread 😂
I'm just jealous. 🙁
Here are the parts I got today.
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003That's more than I've bought for my Jeep lately.
I used to wheel a lot. . .- RobD SubscriberRobD Subscriber__________________ 'If we ever forget that we're one nation under God, then we will be a nation gone under."- Ronald Reagan
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003I used to wheel a lot. . .- Guest former userGuest former user
"RobD" wrote: Will yours look like this 😀 😀 😀 😀 😀
With flames and everything? You can roll with Alex. 😎 - Guest former userGuest former user
"Bender" wrote: [quote="RobD"]Will yours look like this 😀 😀 😀 😀 😀
With flames and everything? You can roll with Alex. 😎that paint job sucks. its like, o, i think i want flames but maybe i can just use a sharpie and draw some in.
i do like the paint on the jeep tho. 😳
Fred SubscriberFred SubscriberA guy I work with has the previous generation Tundra with that lift or one similar. It looks pretty good.
Fred SubscriberFred SubscriberYou should lift it then put the original wheels & tires back on. That would make the lift look huge. You could even paint the wheels with some of that shiny chrome paint. 😂
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003"FAM" wrote: You should lift it then put the original wheels & tires back on.
That's step #1. It will be a while before I can get the tires.I used to wheel a lot. . .
Fred SubscriberFred Subscriber"JohnDF" wrote: [quote="FAM"]You should lift it then put the original wheels & tires back on.
I mean the original steel wheels and little tires that came on your truck. Didn't you already upgrade to nicer factory wheels?
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 2003Yes, nicer wheels but the same size tires.
How big of a tire do you want to go to?
JohnDF Member Joined: July 2003JohnDF started this Member Joined: July 200333-34 inch tire
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003Say John, did you call Les Schwab for an estimate on this lift? F2 (Guy on the rubicon run) is looking at the same lift for his 08 Tundra.
I think Les Schwab's estimate was a little over 250 installed + you get two alignments. If you checked into their price, what did they quote you?Kathleen and Brad
