Whining sound
  1. Fred Subscriber
    #263 Jul 2008, 12:07 PM
    "Dan-H" wrote: [quote="FAM"][quote="JohnDF"]Removing my serpentine is a major pain in the butt (YORK has to be removed).
    Sorry, I'm about out of ideas. Maybe someone else will come up with something else.
    pull your rear shaft, drive in FWD and see if the noise continues.
    He said he can also hear the whine, although not as loud, if he's sitting still.
    #273 Jul 2008, 1:33 PM
    Problem fixed. Thanks Justin πŸ˜€
  3. Fred Subscriber
    #283 Jul 2008, 1:36 PM
    "JohnDF" wrote: Problem fixed. Thanks Justin πŸ˜€
    Gonna tell us what it was?
    #293 Jul 2008, 1:42 PM
    He told me to turn up the radio, and sure enough, the noise went away πŸ˜€
    #303 Jul 2008, 2:04 PM
    Wow...I'm confused, can you redescribe the symptoms? πŸ˜‚ I'm still not clear if it make the noise while sitting still, but I'm slow. 😳 My first thought was rear end too. That's what mine did. Then it went from whine to clunk clunk clunk. If it only makes the noise while moving, pull the rear drive like Dan said.
  6. Fred Subscriber
    #313 Jul 2008, 2:13 PM
    "Bender" wrote: Wow...I'm confused, can you redescribe the symptoms? πŸ˜‚
    I'm glad I'm not the only one. :rasta:
  7. Dan-H Subscriber
    #323 Jul 2008, 2:28 PM
    "FAM" wrote: [quote="Bender"]Wow...I'm confused, can you redescribe the symptoms? πŸ˜‚
    only one what?
    #333 Jul 2008, 2:51 PM
    Sitting still in the parking lot, out of gear, not moving, it will make the noise.
    Driving it will make the noise louder.
    Driving, take it out of gear, rev the engine, it makes the noise.
    Driving, push in the clutch, rev engine, it makes the noise.
    What's on first πŸ˜›
  9. Dan-H Subscriber
    #343 Jul 2008, 3:05 PM
    "JohnDF" wrote: Sitting still in the parking lot, out of gear, not moving, it will make the noise.
    Try Joint Juice.
  10. Fred Subscriber
    #353 Jul 2008, 3:09 PM
    This tells me its not the axles, driveshafts, or t-case
    "JohnDF" wrote: Driving, take it out of gear, rev the engine, it makes the noise.
    This pretty much rules out the transmission.
    I still think its something driven by the engine being the problem or a vacuum leak, possibly the intake manifold gasket.
    Edit) You could be hearing the fuel pump but it makes a pretty consistent sound. I can hear mine if I pay attention to it, but the sound doesn't change with rpm's.
    #363 Jul 2008, 3:20 PM
    I was going to guess that it was the squirrels, but then I remembered that you don't drive a Toyota. 😳 πŸ˜‚
    #373 Jul 2008, 3:21 PM
    Does it sound like a jet engine? Is it possible that some one switched motors while you weren't looking.
    #383 Jul 2008, 3:21 PM
    It appears that I have run out of useful things to add to this thread. πŸ˜€
    #393 Jul 2008, 3:40 PM
    It does sound kinda like a vaccum. My usual diagnosis technique is to wait it out until something falls off or it explodes. Then I just look for the missing part or the charred remains. I was trying to be a little more proactive this time.
  15. Fred Subscriber
    #403 Jul 2008, 3:48 PM
    Get some sensor safe carb/fuel injector cleaner or starting fluid in an aerosol can. I've even used brake cleaner in a pinch. With the engine running, spray a little bit on your hoses or other areas that could be the source of a vacuum leak. If you find a spot where the engine rpm changes dramatically you've found the source of the leak.
  16. Fred Subscriber
    #413 Jul 2008, 3:51 PM
    Your air filter hasn't fallen off or gotten a hole in it, has it?
    #423 Jul 2008, 4:01 PM
    I'll investigate further and report what i find.
  18. Justin Subscriber
    #433 Jul 2008, 4:07 PM
    "FAM" wrote: Get some sensor safe carb/fuel injector cleaner or starting fluid in an aerosol can. I've even used brake cleaner in a pinch. With the engine running, spray a little bit on your hoses or other areas that could be the source of a vacuum leak. If you find a spot where the engine rpm changes dramatically you've found the source of the leak.
    I use propane to perform what Fred is describing above.
    Bring it by my shop John.
    #443 Jul 2008, 4:16 PM
    I need to bring the Subi by your shop too πŸ˜€
  20. Justin Subscriber
    #453 Jul 2008, 5:02 PM
    "JohnDF" wrote: I need to bring the Subi by your shop too πŸ˜€
    I'm open tomorrow or Saturday morning. πŸ˜‚
    #463 Jul 2008, 6:34 PM
    Saturday morning sounds good.
    I like this forum. I can talk to you.
    You know I hate to call you πŸ˜‰
  22. RobD Subscriber
    #473 Jul 2008, 9:31 PM
    Air leak on the air intake.
    #483 Jul 2008, 9:34 PM
    Thanks Rob 😎
    Get back to work πŸ˜›
    #494 Jul 2008, 7:31 AM
    "JohnDF" wrote: Thanks Rob 😎
    Rob has been awful quiet lately, maybe he needs a day off. πŸ˜‚
  25. Fred Subscriber
    #507 Jul 2008, 6:53 AM
    Any updates?
