3:58 pm
I've got most of my Jeep problems fixed. But, I still have a whining sound. Maybe you guys can help me pinpoint it. It's a high pitch whine, not quite a whistle. It is RPM sensitive, gets louder when RPMs clinb up. The gears must be engaged to make the sound, I can't just rev the engine and make it happen. It totally disapears in fourth gear. Remember, it can't be in the front because I have locking hubs, so nothing is turning up there. Ideas?
My first thought is the transfer case...
4:54 pm
May 4, 2004
If the noise is strictly rpm related and not speed related, my guess is the transmission is what's whining. You might want to check/change the oil in the transmission, particularly if you've been in water recently. It could be the breather tube came off the transmission and now you've got some water in it.
Didn't this start after your last Fordyce trip?
5:10 pm
May 4, 2004
"JohnDF" wrote: CORRECTION:
I just drove it and it does make the noise when not in gear...i.e...I can rev the engine and it will increase the whining...so it must not be gear related.
So you can hear the whining when you're sitting still? Try it in with your foot off the clutch and transmission in neutral and also try it with your foot on the clutch.
5:45 pm
May 4, 2004
I'm not a doctor but I played one when I was a kid . . . My diagnosis, based on what you've said so far, is you've got a problem in the rear end. Considering the whining is louder when you're under load than when you're coasting, my first thought is its a ring & pinion set up problem. I don't think you've had any r&p work done recently so it could be worn pinion bearings allowing slop and misalignment in the pinion to ring gear fit.
I would start by pulling the rear diff cover and checking for water and/or metal flakes in the oil. Also check for any broken or oddly worn teeth on the r&p.
My next guess would be the rear wheel bearings. I suppose it could be as simple as a dried up and worn rear driveshaft ujoint.
6:26 pm
May 4, 2004
So you hear the whine when your Jeep's sitting still, coasting down the road, and hear it even louder when you're accelerating. And earlier you said you could hear the whine with your foot on the clutch and also if your foot was off the clutch.
With that criteria, I would say the whine has something to do with your engine. Maybe one of the belt driven items - power steering pump, alternator, a/c compressor, York air compressor, water pump. It might also be a vacuum leak - hose, intake manifold, etc.
You might be able to remove the serpentine belt and run the engine for a very short time. If there's no more whine you know it's something driven off the belt. But don't do this very long. Your water pump won't circulate water and your engine will overheat very quickly.
7:02 pm
February 5, 2003
"JohnDF" wrote: Why would a R&P whine louder when the clutch is engaged and was not under load?
it has to do with drive side and coast side gears.
I would pull the cover check for bad mojo, and if it otherwise looks OK,
put some gear marking compound on the gears, run it around for a few turns,
Then take some pics and post them on pirate general as a "gear pattern check thread"
If might be a clue of a problem or they might be fine.
