Anywhere in Sacramento have any 22LR ammo reliably in stock or is as bad down there as it is up here? I've got an annual spring trip coming up and the shelves are bare up here. The guy at Big 5 says you have to be there when they unload the truck and they sell out as fast as they can ring the people up. That's with a limit of one brick per person. Similar story at the other stores I've checked. 😲
22LR Ammo?
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012It's sold out every where. I've seen it going for $40 a brick on Calguns.net
Gregulator Member Joined: February 2012Gregulator Member Joined: February 2012I've got a brick or two if you get in a bind that we could probably workout a deal.
scoped Subscriberscoped SubscriberI've been out for about a month with a couple shipments of 10-20000 rds here and there - when did you need it by?
Tom SubscriberTom Subscriber"scoped" wrote: I've been out for about a month with a couple shipments of 10-20000 rds here and there - when did you need it by?
I'll be looking you up as well. Any idea when your next shipment of .22LR will arrive?
I'm looking at early-mid April. Any idea if the supply will level out by then?
"finder_87" wrote: I've got a brick or two if you get in a bind that we could probably workout a deal.
Thanks...I've still go some time so I'm hoping I can work it out. I also have a little stashed away. Just don't have the time to stand around in the store waiting for them to unload a truck. Absolutely crazy.
scoped Subscriberscoped SubscriberNo idea when I'll be getting anymore as we can't find any. It's just if we get lucky and find it or if my main distributor gets enough they normally hold some for me. The only problem is alot of the distributors currently limit me to 5 cases a order.
- I'm hoping coming into march things will come back around some but no saying for sure - this is the worst I've ever seen it. I have 5 centerfire autoloading pistols in my store with my normal stock being closer to 200
And I'm completely out of 22, 223/556, .40, .357, .308, 9mm, and I'll probably be out of .45 by the weekend- RobD SubscriberRobD Subscriber
I have 25,000 rounds of 22lr. I might sell you a few if you are desperate, but you can still find it if you frequent stores like Walmart, etc. You just need to be there when they get a shipment in.
