23 degrees here this morning. My pipes froze and I have no water 😤
C-C-C-Cold
JohnDF SubscriberJohnDF SubscriberI used to wheel a lot. . .- Guest former userGuest former user
Frozen pipes are a bummer especially if they break 😢
The news said that Sacramento is one degree away from the the record!
JohnDF SubscriberJohnDF started this SubscriberLuckily there aren't any broken pipes. I have the pipes wrapped but they still froze. I will have to wrap them some more I guess.
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003Bummer. 27 over here...
It was a balmy 17 when I left the house this morning. All my pipe insulation held up though. 😎
Tom SubscriberTom SubscriberI was concerned when the forecast was updated yesterday.
When the temperature at 9PM was 29* in Elk Grove, I went out and covered my lime tree then brought in the brass monkeys.
Jeff- that guy with the foolsize SubscriberJeff- that guy with the foolsize SubscriberI started work at 4:50 am this morning doing a 250 yard pour out at the Folsom spill way. We spent all morning fighting trucks water systems freezing. Not being able to add water or wash out concrete is never a good thing.
Warming up the Jeep this morning at 4:30 it was 22 degrees and my window zipper got stuck - couldn't get the window closed.
Had to take my upper window out and trade with Joe so I wouldn't turn into a POPSICLE 😲 on the way to work!
JohnDF SubscriberJohnDF started this SubscriberI got more wrapping on the pipes today. Hopefully they won't freeze again.
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"SLM" wrote: Warming up the Jeep this morning at 4:30 it was 22 degrees and my window zipper got stuck - couldn't get the window closed.
Yikes! And that was inside your garage I assume.Kathleen and Brad- Guest former userGuest former user
I hope it wasn't that cold in the garage !! I hope that was outside.
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"jsmorrow" wrote: I hope it wasn't that cold in the garage !! I hope that was outside.
You leave your jeep outside at night? And it still likes you? Mine would stop talking to me...Kathleen and Brad- Guest former userGuest former user
"BKGM Jeepers" wrote: [quote="jsmorrow"]I hope it wasn't that cold in the garage !! I hope that was outside.
Jeeps are moody. 😁
JohnDF SubscriberJohnDF started this SubscriberNo, Brad's Jeep is just spoiled 😁
Mine on the other hand is abused...somebody should calll Jeep Protective Services 😈I used to wheel a lot. . .
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"JohnDF" wrote: No, Brad's Jeep is just spoiled 😁
I believe Keane might make a good foster home, but he leaves his "kids" outside too...Kathleen and Brad
Tom SubscriberTom SubscriberAlso appears we'll have a reason to drive up to Iron Mtn Road in a couple of weeks ... YAY!!
"TomD" wrote: Also appears we'll have a reason to drive up to Iron Mtn Road in a couple of weeks ... YAY!!
Need to get my front bumper back on!!! - Guest former userGuest former user
No it sleeps inside, it's a garage queen...
