JKs have a problem where the car will start, run for 3 seconds, and then die. I have that problem but I can't remember how to fix it.
any ideas?
any ideas?
May need to replace the battery in the key.
Thanks Everyone!
ill try the key first. Then the hemi swap...
BKGM Jeepers said Thanks Everyone! ill try the key first. Then the hemi swap...
That's backwards thinking
Thanks. This is one of the many crappy Jeep reliability items.
about 5 years ago I had an ignition problem and the replaced all the related electrical, and my keys. This was one of those original keys apparently.
Lovely. I should make a list of all the problems I've had on this jeep in my almost 23,000 miles of ownership (9 years)...
JohnDF saidThat's backwards thinking
I have to agree with John. If you did the Hemi swap, you would need to change or reprogram keys anyways, right?! 😀
BKGM Jeepers said Thanks. This is one of the many crappy Jeep reliability items. about 5 years ago I had an ignition problem and the replaced all the related electrical, and my keys. This was one of those original keys apparently. Lovely. I should make a list of all the problems I've had on this jeep in my almost 23,000 miles of ownership (9 years)...
It's clearly because you don't drive it enough! So it's fixed?
Yes. Just using my old key by accident.
