buckallred said
Excellent post, thanks for sharing! I personally would love to have you give a presentation during one of our club meetings and I'm sure the other guys (and girls!) will agree.
And sorry, but I have to ask a few quick questions:
1) "Repeaters." The concept is that a ham radio (whether handheld, in a vehicle, or a base station at one's home) broadcasts a signal (on a pre-assigned frequency) to a "repeater," which essentially is an automated radio with a very large antenna that "repeats" the signal. The effect of this is that the signal is re-broadcast (or "repeated"😉 from the very large antenna such that it can extend very far, sometimes around the world depending on atmospheric conditions. Correct? And what if someone responds to the signal? Maybe a dumb question, but anyone wanting to respond to that signal had better have a big antenna (or a repeater) themselves, correct? Otherwise you won't be able to hear them (receive the signal).
2) When you buy a ham radio, what frequencies are you able to broadcast/receive on? Is that predetermined? Can you [legally] modify your ham radio to broadcast/receive on additional frequencies? How does that work?
3) Antennas (or is "antennae?"😉: From your post, I understand that your antenna basically needs to match the frequency in which you try to broadcast. In other words, a CB radio user simply buys an off-the-shelf antenna (whether a whip or a fiberglass, etc), and assuming the antenna is properly grounded and the Standing Wave Ratio ("SWR"😉 is not too badly off, it should work. It should be tuned to work optimally, but even if it is not properly tuned it should at least function. How does this differ for ham radio operators? More specifically, what is your recommendation for a functional antenna for an off-road rig that doesn't break the bank (if such a thing exists, ha ha)?
4) What's the difference between a ham radio and a 10 meter radio? On 10 meter radio, you can broadcast/receive on CB frequencies, correct? Can you also do that on a basic ham radio? Are they the same thing?
1) Essentially... Repeaters are a computer controlled radio (that is then controlled remotely by a Ham... Frank Yost controls the rubicon .805 system). When you tune to a repeater, and then transmit a signal to it, the repeater takes that incoming signal and simultaneously blasts it out at a higher power, from a bigger antenna, from a high up location (usually on top of a mountain or ridge). You don't need an equally adequate antenna in order to receive a signal from a repeater.
2) It depends on the radio... any radio that you are allowed to use as a technician license (for offroading use) will operate on the "Amateur Allocated" frequencies. There are certain ones that will have the ability to receive signals on other frequencies, but the radio will be locked out of transmitting on anything other than the ham frequencies. You can legally receive ANY signal in the air (including cell and Wi-Fi and NOAA Satellite signals... which is fun haha), but in order to transmit, you need to have certain licenses.
3) You pretty much have the gist of it... You need to make sure your SWR is as close to a 1:1 match as you can get it for any antenna. In order to do that, you will need to "tune" the antenna by making it the proper length. Once the antenna is the proper length for what frequencies you are trying to use, the SWR will be low. They go hand in hand. For a CB off the shelf? No idea lol... I would have to do some research. For Ham antennas... You can find many options that will work without any tuning necessary. It depends on if you want a magnetic mount, or if you want to hardwire it in to your rear tire carrier or something. Ham antennas (that operate in the tech license range of frequencies) usually don't require any tuning because they operate at such a smaller frequency wavelenght than CB does. I don't know how else to explain this other than with pictures lol, so you will just have to wait until the presentation at the club meeting for this one. You can get perfectly awesome magnetic mount antennas starting around 25$ for ham. And hardwired antennas around the same price. The better antennas are going to max out around 70$. I highly recommend getting whip style antennae for offroading usage.
4) A 10 meter radio is a ham radio. A ham radio is not necessarily a 10meter radio. You cannot broadcast/receive CB on a 10meter radio (unless it has been modified). CB frequencies run in the 27mhz area(11 meter)... 10 meter ham frequencies run in the 28-29mhz spectrum. A 10 meter radio MIGHT be able to receive CB frequencies out of the factory, but they should not be able to transmit on CB. You need a license to transmit on 10meter bands. Here is a good link that might describe it a little better.... https://www.wearecb.com/10-meter-radios-and-accessories/
Great questions!
Would we want to do a presentation in August or Sept?
