Interesting information
    #17 Jul 2009, 8:23 AM
    Does anyone have any interesting information to share?
    For example:
    Did everyone know that the new MT/R comes in a 38/14.5/17? I didn't know that until last night. That will probably be my next tire on the yellow jeep, and then the black jeep.
    Has anyone gone to the Sierra Trading Post Outlet in Reno? I think Keane knew it was there.
    Does everyone know that Scheels is about twice the size of Cabellas and Bass Pro Shop? I think Fred has been to Scheels in Sparks. We went this past weekend.
    #27 Jul 2009, 8:29 AM
    nobody likes my IFS or my tow points. πŸ™
    #37 Jul 2009, 8:30 AM
    I make it a point to stop there every time I go over! Usually plenty of good deals to be had!
  4. JohnDF Subscriber
    #47 Jul 2009, 8:42 AM
    Did everyone know that the new MT/R comes in a 38/14.5/17? .
    I told you that weeks ago...here's a pic of the 38s next to the 37s 😎
    I'll be going with those or the Maxxis Creepy Crawlers in 38x13.0x15.
  5. JohnDF Subscriber
    #57 Jul 2009, 8:44 AM
    Great thread idea by the way 😎
    #67 Jul 2009, 8:48 AM
    whats the cost differnce between the 38's and 40's anyway?
  7. Fred Subscriber
    #77 Jul 2009, 8:49 AM
    "BKGM Jeepers" wrote: I think Fred has been to Scheels in Sparks.
    Teddi and I went with Lee and Pam to Cabela's in Reno.
    #87 Jul 2009, 9:03 AM
    "JohnDF" wrote: [quote="BKGM Jeepers"]
    Now that is a good pic! It shows the difference between the two sizes of the same tire.
  9. Fred Subscriber
    #97 Jul 2009, 9:06 AM
    "BKGM Jeepers" wrote: [quote="JohnDF"][quote="BKGM Jeepers"]
    If those tires are mounted they're mounted with the wrong side out. The guy at America's Tire did that with my new spare. πŸ™„
    #107 Jul 2009, 9:08 AM
    The tires on the jeep are mounted! Are they backwards? It seems the lugs roll the correction direction. Should the tires be flipped and reversed?
    #117 Jul 2009, 9:08 AM
    "FAM" wrote: [quote="BKGM Jeepers"]I think Fred has been to Scheels in Sparks.
    You haven't been to Scheels yet? Road trip?
  12. Fred Subscriber
    #127 Jul 2009, 9:26 AM
    "BKGM Jeepers" wrote: [quote="FAM"][quote="BKGM Jeepers"]I think Fred has been to Scheels in Sparks.
    Not yet. Actually I had never heard of Scheels before you mentioned it a while back.
  13. Fred Subscriber
    #137 Jul 2009, 9:27 AM
    The closer spaced tread blocks are suppose to be toward the inside of the vehicle. Take a look at Rob's picture in this topic - viewtopic.php?f=31&t=4069
    Take a look at the pictures in this review too - http://www.trucktrend.com/features/cons ... index.html
  14. JohnDF Subscriber
    #167 Jul 2009, 11:15 AM
    Did you know that Genright makes high line tube fenders 😎
  15. JohnDF Subscriber
    #177 Jul 2009, 12:59 PM
    The Webuilt club will be fixing the off camber ledge on Fordyce next weekend.
    The only really hard part of the little sluce is the opening obstacle.
    I can use Rubicon inner axle shafts as spares. They are 1/4" shorter than mine.
    It's hard to buy guns and ammo right now because Obama raised the taxes sky high.
    So there was a run on firearms. Nice plan there Skippy. At least we have a well armed society.
    Justin went to the Rubicon over the 4th and hasn't bothered to tell us how it was 😈
    #187 Jul 2009, 1:08 PM
    I found this information on pirate very interesting. They broke axles with a machine.
    PRODUCT ............................................ FT.LB. TORQUE.... Deg. of TWIST
    Yukon 4340 Dana 60 35 spline short side axle.........12,000......130
    Stock Dana 60 35 spline short side axle ..................6,500........35
    Yukon 4340 Dana 44 30 spline short side axle ..........5,800 .......35
    Stock dana 44 30 spline.......................................5,000 ........35
    Yukon 4340 Birfield Eliminator kit (ear failure)............5,500.......50
    Longfield Toy 4340 30 spline (shaft failure)...............8,500.......175
    Longfield Toy 4340 27 spline..................................6,500..... ..75
    Stock Toyota Birfield.......................................... ..4,200 ......45
    Stock Toyota Inner Axle........................................5,000 .......45
    All Pro "Profield".................................... .... .......... 3,500 ......30
    TJ Rubi Longfield front...........................................6, 800.......75
    TJ Rubi Superior front (shaft failure).........................5,800........40
    TJ Rubi US Alloy front............................................5 ,000........40
    TJ Rubi Yukon front............................................. .4,100........50
    TJ Rubi stock front (ear failure)...............................2,500...... ..10
    TJ Rubi stock front (ear failure)...............................2,000...... ..10
    So a stock D44 30spline is far stronger than a stock Rubi...
  17. JohnDF Subscriber
    #197 Jul 2009, 1:24 PM
    The Rubi axles are necked down to work with the unit bearing. That makes them weaker.
    And I don't see any info on the stock Evo axles, only the Rubi stuff and it doesn't specify Evo.
    #207 Jul 2009, 2:03 PM
    Sierra Outfitters had a product called "express boil" that can boil water in 120 seconds. It was 20% off this past weekend...
  19. Dan-H Subscriber
    #218 Jul 2009, 7:00 AM
    there is a gadget I just saw a few days ago that allows you to get wired ethernet across home power wiring.
    it plugs into the wall and can move room to room.
    I guess these have been out for a while, but I've not noticed them. Prices seem to be all over the place but, way cheaper than tearing up drywall to run cat6 cable.
    http://review.zdnet.com/product/bridges ... k/31970278
    #228 Jul 2009, 8:51 AM
    "Dan-H" wrote: there is a gadget I just saw a few days ago that allows you to get wired ethernet across home power wiring.
    very cool. 😎
  21. RobD Subscriber
    #238 Jul 2009, 11:35 AM
    You took the easy line, most people go up the middle over the big rocks, not around them πŸ˜‰ ..I will show you when my Jeep is done πŸ˜€
  22. JohnDF Subscriber
    #248 Jul 2009, 8:45 PM
    "RobD" wrote: You took the easy line, most people go up the middle over the big rocks
    Big words from a guy that couldn't even make the easy line πŸ˜‚
    #258 Jul 2009, 8:53 PM
    The rash caused by poison oak can last up to 30 days. πŸ™
