I was surprised to see this. Kindof cool they can predict this 4 days ahead of time
...WET AND WINDY WEATHER MONDAY THROUGH WEDNESDAY...
ABUNDANT MOISTURE FROM RECENT SUPER TYPHOON MELOR IN THE WESTERN
PACIFIC IS HEADING TOWARDS THE WEST COAST OF THE U.S. NWS COMPUTER
MODELS COMBINE THIS MOISTURE WITH A POWERFUL JET STREAM AND DEVELOP
A STRONG STORM THAT MOVES INTO THE AREA EARLY NEXT WEEK. THIS STORM
HAS THE POTENTIAL TO PRODUCE A SIGNIFICANT AMOUNT OF PRECIPITATION
FOR INTERIOR NORTHERN CALIFORNIA LATE MONDAY THROUGH WEDNESDAY ALONG
WITH STRONG WINDS.
CURRENTLY...PRECIPITATION LOOKS TO BEGIN IN THE COASTAL RANGE
MONDAY AFTERNOON SPREADING OVER INTERIOR NORTHERN CALIFORNIA BY
MONDAY EVENING. PERIODS OF HEAVY PRECIPITATION ARE POSSIBLE
TUESDAY INTO TUESDAY NIGHT WITH MORE SHOWERY WEATHER LIKELY
WEDNESDAY. PRECIPITATION AMOUNTS FROM MONDAY THROUGH WEDNESDAY IN
THE CENTRAL VALLEY COULD EXCEED 2 INCHES WITH 3 TO 7 INCHES
POSSIBLE IN THE FOOTHILLS AND MOUNTAINS. SNOW LEVELS ARE EXPECTED
TO REMAIN HIGH THROUGH THE EVENT...GENERALLY ABOVE 7000 FEET.
VERY STRONG WINDS COULD ACCOMPANY THIS STORM...ESPECIALLY TUESDAY THROUGH
TUESDAY NIGHT. AT THIS TIME IT APPEARS WINDS IN PORTIONS OF THE
CENTRAL VALLEY COULD REACH SUSTAINED SPEEDS UP TO 40 MPH WITH
HIGHER GUSTS. WIND IN THE FOOTHILLS AND MOUNTAINS COULD BE
STRONGER WITH GUSTS TO 60 MPH OR MORE. WINDS OF THESE SPEEDS CAN
CAUSE PROPERTY DAMAGE AND DOWN BRANCHES OR TREES.
MAIN STEM RIVERS AND STREAMS ARE RUNNING LOW FROM THE SUMMER AND
ARE NOT EXPECTED TO HAVE SIGNIFICANT IMPACT. HOWEVER EXCESSIVE
RUNOFF FROM HEAVY RAINFALL COULD PRESENT FLOODING ISSUES FOR
SMALLER STREAMS AND TRIBUTARIES ALONG WITH URBAN AREAS. IN
ADDITION...HEAVY PRECIPITATION FALLING ON BURN SCAR AREAS FROM
PAST FIRES COULD LEAD TO DEBRIS FLOWS.
THIS STORM HAS THE POTENTIAL TO PRODUCE SIGNIFICANT PRECIPITATION
AND STRONG WINDS FOR INTERIOR NORTHERN CALIFORNIA EARLY NEXT WEEK.
LOOK FOR MORE DETAILED STATEMENTS TO BE ISSUED AS THE STORM GETS CLOSER.
severe weather alert
Dan-H SubscriberDan-H SubscriberClosed Mondays.- Guest former userGuest former user
JohnDF SubscriberJohnDF SubscriberJust be happy you can actually dig in your soil. I couldn't put in a drain line without a jackhammer right now π
On another note...it might be time to put the top on the Jeep π’I used to wheel a lot. . .- Guest former userGuest former user
"JohnDF" wrote: Just be happy you can actually dig in your soil. I couldn't put in a drain line without a jackhammer right now π
That's several days with a pick to get that far. It's rock solid clay up here!
Dan-H SubscriberDan-H started this SubscriberI'm having all of my windows replaced. The last 8 windows are being cut out today and the stucco guy has just started patching things up.
Today the stucco guy asked if he could work the weekend. (I guess they check the weather too).
Huge mess. 2 inches of rain will be AWESOME to wash it all away.Closed Mondays.
Fred SubscriberFred Subscriber"Dan-H" wrote: I'm having all of my windows replaced.
We need to do that too. What brand did you go with and which company are you working with?
Dan-H SubscriberDan-H started this SubscriberWe went with M i l g a r d windows installed by S o u t h g a t e G l a s s. the sales guy is " j e f f @ sou th ga te glass . com ". he was easy to work with. S G Glass is one of the main Mg dealers in the area.
I learned there are a lot of ways to replace windows. I went with the more labor intensive way which is the new-construction style with a nail-fin not a replace ment style that fits in the existing frame. It added a bit to the cost, but in the end I wanted the house to look like the windows belonged, nut just bolted on to fix a problem.
So far I'm really impressed with the crew, actually 2 crews (4 guys) going at it for 5 days now. Yesterday and today a 5th guy showed up.
The windows are fantabulous. I picked the T u s c a n y vinyl because I wanted double hung windows upstairs. We got the S u n c o a t 3D-max option, which is C a r d i n a l G l a s s L o E 3 6 6 filled with argon gas with foam spacer's between the glass. and they block out a ton of heat. It hasn't been cold enough to notice the difference yet.
They sub'd out the stucco work and the guy looks really good. He did some prep work yesterday and brought a crew today.
Give me a call and stop by next time your up this way if you want to check them out. They should be "done-done" monday or tuesday...
-- I put extra spaces in so this thread doesn't show up in searches --Closed Mondays.- Guest former userGuest former user
Consider this thread jacked!
We put the argon filled G r eat L ak es windows in our house in Rancho. I think we got them through We athe r i t e. We did the easier of the two installs and were very happy with it. They were in and out in a day!!! They were very professional. I'm not sure what brand we have at the new house, but they're also the easier install type. They look great, the only drawback is that they look like they have a thicker frame. I can take some pictures if you want, but our windows are dirty now. π³
When we got our windows we stayed away from M il lg ar d because my parents had terrible luck with them. They had about 5 or so of them replaced. The warranty was unbeatable and they were replaced at no cost, but they were a hassle. The warranty we got was basically the same.
I added spaces because they look cool and make it difficult to read. π
JohnDF Subscriber
Fred SubscriberFred SubscriberW elik ed th elo ok ofth e Ander son Ren ewe l windows when we saw them at the home show. But we didn't look at too many brands.
I tried to type like that but it took too much thinking. :rasta:
Dan-H SubscriberDan-H started this Subscriber"FAM" wrote: W elik ed th elo ok ofth e Ander son Ren ewe l windows when we saw them at the home show.
When I got bids, the And er son Rene wal were double the pri ce, actually a bit more than double.
And M i l g a r d has a better warranty.
I liked the Re new al too, but I couldn't justify the cost difference.Closed Mondays.
JohnDF SubscriberJohnDF SubscriberWh yar eyo uguy stypin glik ethi s?
Dan-H SubscriberDan-H started this Subscriberto distract the evil search robots.
JohnDF SubscriberJohnDF SubscriberYou guys are soooooo paranoid π²
Dan-H SubscriberDan-H started this Subscriber...HEAVY RAINS AND STRONG WINDS POSSIBLE TUESDAY INTO WEDNESDAY...
MOISTURE FROM THE REMNANTS OF SUPER TYPHOON MELOR IN THE WESTERN
PACIFIC IS MOVING ACROSS THE CENTRAL PACIFIC OCEAN AND IS FORECAST
TO REACH THE WEST COAST EARLY NEXT WEEK. COMPUTER MODELS COMBINE
THIS MOISTURE WITH A POWERFUL JET STREAM AND DEVELOP A STRONG
STORM THAT MOVES THROUGH THE AREA. THIS STORM HAS THE POTENTIAL TO
PRODUCE A SIGNIFICANT AMOUNT OF PRECIPITATION FOR THE INTERIOR OF
NORTHERN CALIFORNIA TUESDAY AND WEDNESDAY ALONG WITH STRONG WINDS.
CURRENTLY...PRECIPITATION LOOKS TO BEGIN IN THE COASTAL RANGE AS
EARLY AS MONDAY AFTERNOON AND WILL SPREAD INLAND ACROSS THE INTERIOR
OF NORTHERN CALIFORNIA MONDAY NIGHT AND TUESDAY. PERIODS OF HEAVY
PRECIPITATION ARE POSSIBLE TUESDAY AND TUESDAY NIGHT WITH MORE
SHOWERY WEATHER LIKELY WEDNESDAY. PRECIPITATION AMOUNTS IN THE
CENTRAL VALLEY COULD EXCEED 2 INCHES WITH 3 TO 7 INCHES POSSIBLE IN
THE FOOTHILLS AND MOUNTAINS. SNOW LEVELS ARE EXPECTED TO REMAIN HIGH
THROUGH THE EVENT...GENERALLY ABOVE 8000 FEET.
STRONG WINDS COULD ACCOMPANY THIS STORM TUESDAY AND TUESDAY NIGHT.
AT THIS TIME IT APPEARS WINDS IN PORTIONS OF THE CENTRAL VALLEY
COULD REACH SUSTAINED SPEEDS UP TO 30 MPH WITH HIGHER GUSTS. WIND IN
THE FOOTHILLS AND MOUNTAINS COULD BE STRONGER WITH GUSTS TO 60 MPH
OR MORE. WINDS OF THESE SPEEDS MAY CAUSE PROPERTY DAMAGE AND DOWN
BRANCHES OR TREES.
RIVERS AND STREAMS ARE RUNNING LOW FROM THE SUMMER BUT WILL
POTENTIALLY SEE SOME SIGNIFICANT RISES NEXT WEEK AS HEAVY
PRECIPITATION DEVELOPS. EXCESSIVE RUNOFF FROM HEAVY RAINFALL COULD
PRESENT A GREATER POTENTIAL FOR FLOODING ISSUES ALONG SMALLER
STREAMS AND TRIBUTARIES...AND IN URBAN AREAS. IN ADDITION...HEAVY
PRECIPITATION FALLING ON BURN SCAR AREAS FROM PAST FIRES COULD LEAD
TO DEBRIS FLOWS.
CLOSER.Closed Mondays.
Dan-H SubscriberDan-H started this SubscriberI'm going to post the changes as it gets closer to see how accurate these com pu ter models are to see if they guessed right.
JohnDF SubscriberJohnDF SubscriberSo...you're saying it might rain next week?
Dan-H SubscriberDan-H started this Subscriber"JohnDF" wrote: So...you're saying it might rain next week?
No, leave the jeep out monday night with the top off. Heck, you can even sleep in it. It's gonna be balmy.Closed Mondays.- Guest former userGuest former user
"Dan-H" wrote: ... com pu ter...
Trying to avoid search engines? π
Dan-H SubscriberDan-H started this Subscriber"Bender" wrote: [quote="Dan-H"]... com pu ter...
y upClosed Mondays.
Fred SubscriberFred Subscriber"Dan-H" wrote: you can even sleep in it. It's gonna be balmy.
I heard it might be a bit humid
JohnDF SubscriberJohnDF SubscriberWh yd oyo ufea rsearc hengine s?
Because.... search engines are the devil!
JohnDF Subscriber- Guest former userGuest former user
"JohnDF" wrote: For you Dan...
Have you been doing some Halloween costume shopping?
