IH Only
  1. Justin Subscriber
    #117 Mar 2008, 6:52 AM
    I wanted to give a thumbs up to IH Only in Loomis again. I had them weld my sway bar brackets on last week. He quoted me a half hour labor and ended up spending an hour on it and adding some nice gussets (which he had in stock) for reinforcements, and he stuck to his original quote.
    He also gave me a bunch of DOM in the right size for building a drive line if I need to at the Hammers.
    If you need welding or fab work done, they do AWESOME work.
    #222 May 2008, 10:32 PM
    IH Only reinforced my trac bar mounts top and bottom. Good stuff
  3. JohnDF Subscriber
    #322 May 2008, 10:33 PM
    :worthless:
  4. RobD Subscriber
    #422 May 2008, 10:40 PM
    Let us see those photos of your upper gussets on the tracbar mount.
    #523 May 2008, 8:45 PM
    It is dark now, soon my friends...soon.
    #624 May 2008, 8:36 AM
    Oh no, now it's raining...sorry... maybe pictures later...
    #724 May 2008, 11:00 PM
    The Rubicon Express track-bar mounting bracket you see was cracked in half on the drivers side. Here are pictures after IH Only rewelded, reinforced, and gusetted it. I also had him add a little metal to the lower mounting point as see in the last couple of pics.
    #825 May 2008, 9:15 AM
    Looks beefy, but do they typically only crack at the frame? Why not beef up the whole bracket instead of only the top couple of inches? There's less mechanical advantage as you move away from the frame, but it looks like you may have just moved the weak point. Of course, I haven't spent much time looking at the connection so I may be picturing it wrong in my mind. 🤷
  9. Justin started this Subscriber
    #925 May 2008, 9:33 AM
    Now it will just rip the whole bracket and reinforced pieces off. 😲
    Looks beefy Tom.
    On a side note. If anybody needs anything from IH Only, stop by there and check out the custom suspension they designed and are building on one of the Scouts in the shop. It's pretty impresive.
  10. JohnDF Subscriber
    #1025 May 2008, 9:54 AM
    The bar I described in the earlier post would be a good addition and responds to Keane's valid concerns.
  11. JohnDF Subscriber
    #1125 May 2008, 9:54 AM
    BTW...loks like some good welds...but I'm no expert.
    #1225 May 2008, 3:55 PM
    I think your right Keane, that the weak spot is just moved.
    I think the bar brace would be a good idea to keep it from moving either way. RE should have some available soon for those who don't want to fab it.
  13. JohnDF Subscriber
    #1325 May 2008, 4:02 PM
    Yada...yada...yada...the important question is...did you catch any fish???
    #1428 May 2008, 5:22 PM
  15. RobD Subscriber
    #1528 May 2008, 5:50 PM
    See all that rust in you bottom picture. That is where cracks and weak spots start. People laugh when I paint my underside, but that helps stop corrosion. The only time I have broken brackets, I could trace the break back to an unpainted area that was rusted.
    #1628 May 2008, 6:07 PM
    what kind of paint? Do you prep it first?
  17. JohnDF Subscriber
    #1728 May 2008, 6:51 PM
    "RobD" wrote: People laugh when I paint my underside, but that helps stop corrosion. The only time I have broken brackets, I could trace the break back to an unpainted area that was rusted.
    I just stopped washing my Jeep all together. Dirt is a better protectant than paint. I break less than you 😉
  18. RobD Subscriber
    #1828 May 2008, 8:05 PM
    "1tom2go" wrote: what kind of paint? Do you prep it first?
    I just use a semi flat black Rust-Oleum...No prep other then making sure it is clean first and not painting over dirt.
    #1928 May 2008, 8:41 PM
    Jeeps must be made of cheap metal. Toyotas don't have that problem.
  20. JohnDF Subscriber
    #2028 May 2008, 9:12 PM
    "Bender" wrote: Jeeps must be made of cheap metal. Toyotas don't have that problem.
    It's just that these guys wash most of the metal away.
    Besides, my Jeep is more Ford than anything else 😉
    #2129 May 2008, 6:36 AM
    "JohnDF" wrote: Besides, my Jeep is more Ford than anything else 😉
    Someday my axels will be too. The tranny on the truck has a leak. Might as well scrap it and use the parts. 😂
  22. Justin started this Subscriber
    #2229 May 2008, 6:48 AM
    Keane, that axle in your truck is a piece of junk. I'll be over later to get it out of your way. 😀
    #2329 May 2008, 6:56 AM
    "Justin" wrote: Keane, that axle in your truck is a piece of junk. I'll be over later to get it out of your way. 😀
    Thanks for the tip. Given your mechanical background I'm sure you know what you're talking about. Do you want me to pull it and clean it up for you too?
