What's up crew. I noticed a small oil leak( 3-4 drops) and it looks like it might be the rear main. Anyone have any issues with this in the past?
Is it a quick fix? Any info would be awesome.
BTW 4.0 TJ, MT.
Ray
Rear Main Seal
Tom SubscriberTom SubscriberLeaking rear main on the 4.0L is VERY common. Replacing requires pulling the transmission. 🤮
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"norcalray" wrote: What's up crew. I noticed a small oil leak( 3-4 drops) and it looks like it might be the rear main. Anyone have any issues with this in the past?
BTW 4.0 TJ, MT.
Ray
2000TJ that I owned for 12 years didn't have any oil leak problems, so I'm no help.
Problems with the crank position sensor - that I have had... :xKathleen and Brad
Tom SubscriberTom SubscriberI've had the 4.0L in both my YJ and XJ. The YJ had about 145K miles when I bought it and the XJ about 150K.
Both had the "dribbles" you describe. Wish they didn't.
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003"TomD" wrote: I've had the 4.0L in both my YJ and XJ. The YJ had about 145K miles when I bought it and the XJ about 150K.
My jeep had under 40K when I sold it, so I didn't have higher miles.Kathleen and Brad
Fred SubscriberFred SubscriberMy Y2K TJ leaks too. It has been for a while but has gotten a little worse lately. Only 68k miles on it too.
I recall Kevin replaced his rear main seal on his YJ shortly before selling it. Maybe he'll see this and add some details.
BKGM Jeepers President Joined: June 2003BKGM Jeepers President Joined: June 2003The project seems like some work (labor) but cheap parts. You'd need to drop the t-case and tranny plus remove the drivelines. At least lifted jeeps are easy to work on...
i would check into this a little more
my cj was a 2piece kit didnt need to seperate bell housing etc..
other wise your in for a days labor
my bronco had to pull transmission etc.. to get to it
if you do by urself get a tranny jack
and on my tj i have 0 leaks after upgrading the steering box (that leaked since day 1)
if it is the 2 piece set up you just remove the oil pan - Guest former userGuest former user
Thanks for all the info. My TJ has around 136k, and just leaves a few drips here and there. Looking on YouTube, there is a method that doesn't require
to drop the trany. The main seal is in 2 pieces so I may try what I saw on YouTube.
http://www.youtube.com/watch?v=ft4LhJWOgtk
Check it out... Gotta love youtube.
Thanks again for all your input. - Guest former userGuest former user
"Rayzor" wrote: i would check into this a little more
Yeah looking at the YouTube video, it's a 2 piece, and he just removes the oil pan and works it around.
Guess I better get it done before Jeep Safari lol..
Thanks for the input.
Tom SubscriberTom SubscriberI'll need to take a look at that as well ... HATE leaks.
k-jeep Member Joined: May 2009k-jeep Member Joined: May 2009I changed the rear main seal on my old YJ. About half way down in this thread.
You don't have to remove the tranny. I followed this thread when I did mine. I still have some of the mopar gasket maker that I don't foresee using again. I can bring it to the meeting if you plan on being there.- Guest former userGuest former user
For what it's worth I did some work at my friends dad's shop today...I can't tell you how nice it was to have a lift and all the right tools.
viewtopic.php?f=18&t=5623 - Guest former userGuest former user
I changed mine out on my 06 tj,pretty easy. As Kevin said you do not have to touch the tranny. Type in Replace(tj,yj,xj,zj) rear main seal and you'll find a hole slew of info. Myself I always pick the ones with pictures. Order up a rear main seal,pan gasket,oil,oil filter,two mountain dews and you'll be good to go.
Tom SubscriberTom SubscriberSounds like a plan when things warm up.
"TomD" wrote: I'll need to take a look at that as well ... HATE leaks.
Tom sounds like we need to have a repair day lol... - Guest former userGuest former user
"rick-rock" wrote: I changed mine out on my 06 tj,pretty easy. As Kevin said you do not have to touch the tranny. Type in Replace(tj,yj,xj,zj) rear main seal and you'll find a hole slew of info. Myself I always pick the ones with pictures. Order up a rear main seal,pan gasket,oil,oil filter,two mountain dews and you'll be good to go.
We're men we like pictures.... Sounds like it should be a quick fix for the most part.. - Guest former userGuest former user
"kevheb" wrote: I changed the rear main seal on my old YJ. About half way down in this thread.
Great pics... Thanks for the visual !!
